Author Topic: Submini Tube Amp Project (Edited w/ more questions)  (Read 8446 times)
printer2
Re: Submini Tube Amp Project (Edited w/ more questions)
« Reply #60 on: December 29, 2017, 03:21:48 PM »
If one were to use a power transformer that's not a wallwart why not just get one that supplies B+ rather than using a power transformer with insufficient power and/or an smps? Seems a bit silly.
Not sure if this refers to the Hammond 229C12 I suggested as an alternative. This one easily supplied the power, 6V and high voltage, to build a 3W 5E3. It was a good match for a 1960's 10" speaker and a full size guitar speaker (much louder). I am hoping to trade back for the amp to come home. If you need more than what the transformer delivers then you are not making a mini amp. Getting suitable sized transformers inexpensively was not an option for me at the time so I used the Hammond.
Fred
Kevin Mitchell
« Reply #61 on: January 02, 2018, 12:33:52 PM »
What really confused me was you suggesting to use a primary tap as a secondary. Could you perhaps share a drawing? I'm just seeing caution signals in my head  :icon_lol:   Maybe this is something I would find useful as power alternative.
I'll be working up a submini amp for my record player since apparently these things only put out phono or line level signals  :o   I'm thinking a stereo champ amp for a super simple amp build. The only thing is... would very likely need two output transformers for stereo amplification & output.
It's time to put this project back on the breadboard!
« Last Edit: January 02, 2018, 12:42:52 PM by Kevin Mitchell »
printer2
« Reply #62 on: January 03, 2018, 10:46:29 AM »
Darn computer froze on me when I tried to post my message, it was probably too wordy anyway. Here is the wiring diagram, 1-2 and 3-4 are the 120V coils, parallel them for 120V or series for 240. Because these windings are on their own plastic bobin they are 100% isolated from each other  and not like a normal transformer where the one winding would be wound one the other.
I I flipped the transformer so the pins faced up rather them stuck in a circuit board. Because of the plastic that supports the pins is in the way of a bolt through the mounting holes I had to file a flat on the side of the bolt head. I bought it as it gave me a flattened transformer to to put in a shallow case. I think if you live in the U.S. there are more options for a regular transformer for tubes. Shipping and brokerage fees kill me at the border.
Fred
Kevin Mitchell
« Reply #63 on: January 03, 2018, 02:01:47 PM »
So the unused primary becomes the high voltage secondary? Could I regulate this supply for 180V - 240V DC? I'm curious to if that tap is sufficient without any drawbacks being used as a secondary and if so - I would certainly snag a few of those transformers. This info is new to me and with my limited experience with power transformers I wouldn't consider thinking outside the box so much.
« Last Edit: January 03, 2018, 02:41:18 PM by Kevin Mitchell »
printer2
« Reply #64 on: January 03, 2018, 05:02:30 PM »
Yeah that is me, outside the box.  :icon_confused:
 I looked up the 5E3 6AK5 amp I built, I used a 70V transformer that had an 1/8 watt tap and I used that as a 16k load for the tubes. I biased them at their plate dissipation limit.
No info on the transformer. I have a few scavenged from renovation at work. This transformer is an oddball as all the other transformers I have are like the ones you are familiar with. The tubes want to see 10k in SE so I went for the highest ratio, for the two tubes it should be 16k with the 1/8W tap. The speaker is across the 1/8 watt tap and the common, the way it is photographed it looks like the lugs are shifted over.
    For the power transformer, for a 1:1 power transformer Hammond (I am guessing others also but since I have not tested any I can not say for sure) winds the secondary with more windings than the primary to make up for losses in the transformer. Since in the above transformer both the 120V windings are suppose to be connected to the line their winding turns are the same. When you use one for the line and the other as a secondary the losses creep in and even unloaded you do not get 120V out.
    Now when you take a AC voltage and multiply it by 1.414 you are calculating the peak voltage of the AC waveform. If you have a rectifier and a capacitor making dc and you have no load on it this is the voltage that will end up on the capacitor. If you draw a reasonable amount of current from it you really only get from 1.1-1.2 times the AC voltage. Also with using the transformer as I had you are loosing half your primary winding so your losses will be magnified.
    Can't remember what the voltage was but say we take 110V AC, multiply it by 1.1 you get 121V and then double it you have 242V, pretty close to the 230V I ended up with. Using the transformer the way I did is far from ideal in terms of what the manufacturer intended, it just works out nicely for my application. The transformer does not have the VA rating that it would have if used normally but it has enough for my little one watt tubes.
I reduced the cathode resistor on the 6AK6's to about 360 ohms. Power supply had SS diodes using a doubler circuit and capacitance values of 22uF. This then fed a 22uF which was the plate supply. I had 230V on the plates and 192V on the screens with a 4.7k and 22uF. Through a 22k to a 22uF I had 140V for the preamp triodes. I had 112V on the cathodyne plate, 29V on the cathode. The second stage triode, 96V on the plate and 0.78V on the cathode. The input stages have 75V and 83V and the cathode with 1.1V on them with just a single 820 ohm.
Looked up a transformer I suggested for an amp like this, think it might be cheaper than the Hammond.
https://www.tubesandmore.com/products/transformer-fender-replacement-power-stand-alone-reverb
And these little buggers I like.
https://www.tubesandmore.com/products/6ak6-pentode
Beats having a triode output tube.
This is my buddy on the amp, he never played a 5E3 so he didn't know how to play with the controls. Ignore the Microsoft sign up window.
http://1drv.ms/1hDNpt3
Oh yeah, going through an old 10" out of a stereo console.
« Last Edit: January 03, 2018, 05:05:07 PM by printer2 »
Fred
Kevin Mitchell
« Reply #65 on: January 07, 2018, 11:53:12 AM »
Sweet! Now I want one of those for myself  :icon_lol:
I've done a fair amount of searches trying to learn the in and outs of phono preamps and came across a nice little circuit called the Mini Me. It's a stereo phono preamp using 4 6N16B tubes. I'm going to experiment with this and try my hand in designing an output preamp and amp (an integrated amplifier) using 6N16B or 6N17B triodes and 6P30B pentodes in a push-pull setup for higher output.
I've found a few projects using these tubes but no schematic that I could work from. I could replicate a low voltage (meaning around 200v) guitar amp since the 6P30B are very similar to 6v6 pentodes and tame it down for the cleanest result.
Now just have to find a couple of decent output transformers that fits the bill.
« Last Edit: January 07, 2018, 12:00:16 PM by Kevin Mitchell »
Kevin Mitchell
« Reply #66 on: January 10, 2018, 09:38:01 PM »
You might not get the full 24VA out but should be fine for a couple watt amp.
Not knowing for sure what the "120v secondary" would be rated at how would I know what primary fuse would be appropriate? Would I have to calculate the current consumption needed for B+ to get the ~VA for this improvised secondary winding? Could you suggest a fuse that would be safe using?
After searching around for output transformers I'm back to this thread doing the math to use line transformers :icon_lol:
Trying to understand how to get ~6k from this line matching transformer for a couple of 6P30B pentodes. This is something I have neglected to do last time I was picking at this project. Gonna take a few more read-throughs  :icon_rolleyes:
« Reply #67 on: January 11, 2018, 09:38:54 AM »
If you were doing single-ended outputs, it would be easy.  You use the equation P = V*I = V*V/R so R = V*V/P
Your 70 volt (actually 70.7 volt) outputs gives you a V*V = 5000 so if you have a 1 watt tap, you have 5000 ohms, if you have a 5 watt tap, you have 1000 ohms between the black (common) lead and the tap.
With 25 volt taps, your V*V is 625.
Push-pull operation gives you the problem of trying to balance the inputs.  The black common lead goes to one plate and you have to pick a centre tap and the opposite plate tap.  In this case, you can get push-pull operation from the 2.5 watt and 0.625 watt taps but the impedance is too low and although the voltages between the common and 0.625 and the 0.625 and the 2.5 has the same number of turns, the winding resistances will not be balanced.  The transformer in your link seems to be drawn wrong.  The highest power taps are closest to the common and the lowest power taps are closest to the opposite end from common.  See this:
https://www.alliedelec.com/m/d/d8292cf7f11c601de4c651a61586c0eb.pdf
for how it should be.  Use the tap with 4 times the power of the other plate tap as the centre tap so if you follow the Hammond drawing, you could use a 4 watt tap as the centre tap and the one watt tap as the opposite plate tap and get 5000 ohms plate-to-plate.
Kevin Mitchell
« Reply #68 on: January 11, 2018, 01:44:27 PM »
Thank you for breaking that down once more, Amptramp.
I have not settled on what format I'd like to use these tubes in but I'd like to avoid SE so I can get the most out of the setup though for the sake of tinkering I might try SE on breadboard to see how it sounds. Maybe it'll be loud enough for what I'm after.
In another forum I guess someone had gotten close to 15W out with a 3K transformer in ultra linear format. I assume that was in reference to plate to CT.
A week ago I had no idea what that meant. Just so you know where I'm at  :icon_lol: So now I'm trying to find an OT that's okay for any format I may throw together on breadboard.
printer2
« Reply #69 on: January 13, 2018, 10:02:45 AM »
A 0.25A fast blow fuse on the primary should be fine.
Fred
Kevin Mitchell
« Reply #70 on: January 13, 2018, 01:20:07 PM »
Off the subject of line matching transformers (I've read they could have low freq response which is suitable for guitar but not sure about a hifi stereo design)
I have found this OT for a reasonable price
I feel this could work fine with a push-pull design with 6P30B pentodes.
EDIT:
Also I'm starting to get a little skeptical about the improvised PT having drawbacks. I may need ~2A at 12V for the entire filament circuit which a little higher than it's secondary rating so I'm unsure if pushing this and using that 120v tap as an extra secondary would be safe. But I could just be uninformed on the matter of current tolerance in this situation.
But I've also found this
After rectifying the taps I'd use this one should be perfect. And it's a couple bucks less  ;)
« Last Edit: January 13, 2018, 02:50:27 PM by Kevin Mitchell »
