Recommend a non latching dpdt relay
Started by Beo, May 08, 2016, 02:58:10 AM
Beo
I've been using latching relays for various projects, but I have a project I want to do using non-latching.
Anyone have any recommendations on specific non-latching relay parts that are available / in production?
Thanks,
Travis
Kevin Mitchell
Check out the CD4053 bypass
Some info
With the CD4053 and CD4049 you can use a soft touch momentary foot switch which are not latching.
This hobby will be the deaf of me
Beo
Thanks, but I'm programming microcontrollers for relay control. Just wondering if there is a recommended Panasonic, Omron, NAIS, or other relay out there that is widely available...  hopefully at a decent price. I've been using the Panasonic TQ2-L-5V and Omron G6HU-2 latching relays to date. These require two uC pins to control, and for my new project I want to control more relays with a single uC, so only want to use one pin per relay.
samhay
There are plenty of fairly cheap 12V miniature non-latching relays and while it's certainly not best-practice, I have had good luck using these on a 9V supply. When you can find the datasheets, they typically show a 'must operate voltage' of 75% of max supply, which means this is just within spec.
