Mixing Positive Ground and Negative Ground
Started by pdavis68, May 17, 2016, 10:54:19 AM
pdavis68
If I built 2 effects into the same box and one was negative ground and one was positive ground (say both are 9V) could I do a +9V/0/-9V supply and use the +9 for the negative ground effect and the -9 for the positive ground effect and have them share the ground?
italianguy63
antonis
#2
Of course you could..!!
(but you'll have to rename it as a vitrual ground circuit..) :icon_wink:
The simplest way is to wire two 9V batteries in series (+ -+ -) and take the GND from the middle..
P.S. Wellcome.. :icon_wink:
edit: @Marc, the terser the faster..
pdavis68
Thanks. Thought so, just wanted to make sure I wasn't overlooking something. Thanks.
