1776effect Rub-A-Dub Deluxe Reverb build....
Started by heathfball20, May 21, 2016, 05:26:51 PM
heathfball20
http://1776effects.com/wp-content/uploads/2015/03/Rub-a-Dub-Deluxe-BOM.pdfhen i apply power to the board, smoke begins to come out from under the TL072 IC. Will this affect the chip? Should i get another? Also, there is not sound when engaged but the bypass works.
Schematic here
jimilee
Yes and yes. Find your shorts before you try again, it's never good when you let the magic smoke out.
Sent from my iPhone using Tapatalk
Quote from: jimilee on May 21, 2016, 07:27:54 PM
Yeah, if you're gonna set things on fire, it's definitely a good idea to have your underwear on.   ;D
heathfball20
Ok, i have the new tl072. How do i know which is the 1st leg? They dont have the indentation like other IC's. Id like to put it in the correct way
heathfball20
Also what would it do if i replaced the 22nf cap with a 33nf cap? Hypothetically. Im trying to understand what everything does. Learning as i go
Quote from: heathfball20 on May 25, 2016, 06:22:35 PM
You'll either have a bite taken out of one end (sounds like this is what you're expecting), or there will be a dot right by pin 1.
Bite:
Dot:
strassercaster
I hate it when that happens. I would suggect getting a new voltage regulator. Make sure you have it in right if its backwards that could cause issues. it needs to be 5 volts. more than likely you have a bridge or something in backwards like an electrolytic cap or the votage regulator
I'd double triple check the pinout for the voltage regulator too. If you can get the data sheet from the supplier it may help.
I hope it is the TL072 and not the brick.
Good luck.
heathfball20
Thanks! That was my main concern. I already used a razor blade to check for solder bridges and checked the pinning on the electrolytics, which look good. . After a 13 hour day today and another tomorrow, i wont be able to get to work on the pedal until Saturday. Ill post to tell if it worked or not.
heathfball20
Yes, just fixed it! It was the TL072 and the tpdt switch. I changed to a dpdt and it now works beautifully! Thanks
