Extra shielding within the box
Started by blackieNYC, May 28, 2016, 11:50:30 AM
blackieNYC
I'm sandwiching two boards together and I thought I'd get cute and ground the insulator between them. Rather than wrapping something in sticky electrical tape, I fold the tape on itself. It makes a thin flexible insulator which you can tape to the inside of the box.
For this one, I've added a sheet of aluminum within, and a length of stripped ground wire. The tape is on both sides, with no sticky surfaces. Could also be employed for "taco shielding".
oooohh. once you've finished yer meat pie, flatten the aluminium tray it came in, cut to shape, then put a sheet of paper over one side, and wrap, front and back, with translucent sticky-back plastic, like for covering excercise books at school (do they still have excercise books?). the plastic might be a bit thin, so the added paper - and, the good bit, you can draw or write things on the paper before wrapping, things like -
a parts list
a circuit diagram
a wiring diagram
a board layout.
blackieNYC
NYC is crazy for Australian meat pies for the last two or three years, btw.  "Tuck Shop" on 1st street.
next you're in there, ask for a rat's coffin, see if they know real strine. or a floater.
chuckd666
Whoa, an Australian food place in NYC... Now I've heard everything. I heard NYC only recently got it's first flat white coffee as well?
Sidetracked.
Whoa indeed you can't imagine how scared I was for the results when I googled
Strine and Australian floater.
Thankful Google has some class. Now I know.
So now they have bush tucker challenges in NYC?
I'd rather have kippers on toast.......classy hey.
ahh, now, bush tucker, that's a whole different grub, kipper.
