Aion Comet Diodes question
Started by spoontex, July 03, 2016, 06:44:47 AM
spoontex
I've just finished the build of a Boss DS-1 clone from Aion. But, they don't work.... I think that I mount the diodes incorrectly. You can check!?!?
thanks.
https://s19.postimg.org/w3kbcv29f/20160703_123907.jpg
https://s19.postimg.org/oc3leay43/ds1_pcb.jpg
roseblood11
You have a schematic and you can see both sides of the pcb. Why dont you check it yourself?  8)
> they don't work....
No sound? Hum? Smoke? Radio stations?
aion
The diodes look OK to me. What's the issue you are hearing?
GibsonGM
Quote from: aion on July 03, 2016, 02:17:55 PM
Or are you not hearing anything at all?  Or just clean sound, no distortion?   .....more data please....
spoontex
I've the diode mode, but they don't light... and the distortion is very soft and low volume. I check all and change the IC but nothing changes.
https://vimeo.com/173283724
You shouldn't necessarily expect to see the LEDs light up.  They're there for clipping, not one of Rob's lightshows.   ;)
spoontex
Thanks.
Anyway the don't work properly.
antonis
#8
Try to replace them with a pair of Ge or Schottky diodes..
Although I think something wrong happens with IC's gain..
spoontex
Voltages:
IC1:
1= 0,745V
2 = 0,744V
3 = 0,728V
4 = 0.00... mV
5 = 0,564V
6 = 0,730V
8 = 8,94V
Q1:
C=3,468V
B=3,91v
E=8,95
Q2:
C=0,000...mV
B=0,000...mV
E=0,000...mV
Q3:
C=3,136V
B=3,433V
E=8,95V
D1:
A=8,95V
K=0
D2:
A=4,46V
K=4,19V
D3:
A=4,19V
K=4,46V
D4:
A=4,46V
K=4,48V
D5:
A=4,49V
k=4,46V
Shematic:
https://s19.postimg.org/3uin2nm0j/schematic.jpg
Q2 sure has a problem (all zeros).
IC1 has a problem (mostly half-Volt).
Your problem is there, not "diodes".
Q1 Q3 are right if you have confused C and E pins. I don't know if the error is in the build or the reporting; it may not matter.
