modding the taper of an Ernie Ball Jr. volume pedal
Started by mordechai, July 25, 2016, 05:09:26 PM
mordechai
I just saw a nice little video from Analogman where he fixed the taper of an Ernie Ball Jr. volume pedal to have a more usable sweep and to have an added buffer to keep the highs there.  I can figure out how to apply the buffer mod, but I'm curious about the taper mod.  He switched it via what looked like a SPDT toggle to show the "with" and "without" of the mod, so I'm guessing he just tacked on a resistor to the pot in the pedal.  Here's the vid:
https://www.youtube.com/watch?v=8myBogxiwmU
Anybody have an idea what value resistor might be involved in this?  I am assuming that the resistor would go between Lugs 1 and 2 of the pot...
strungout
I don't but if you have a pair of alligator clips and a few resistors of different values you could open it up and experiment!
"Displaying my ignorance for the whole world to teach".
"Taste can be acquired, like knowledge. What you find bitter, or can't understand, now, you might appreciate later. If you keep trying".
stallik
Yup, experiment but I'd start with 1/4 to 1/2 the value of the pot and I think you'll hear a difference between placing it between lugs 1&2 or 2&3 so you might like to try both options.
Someone will chime in with a proper calculation but that's my tuppence worth
YouAre
To add to this, instead of clipping in a resistor, why not clip in a pot to make the tweaking process easier? Once you find a value you like, replace the pot with that value resistor.
To add to the fun....check this out.
http://www.guitar-mod.com/rg_diag_treble_bleed.html
If you're REALLY gonna dig into this, I'd graph the volume pedal output in excel. Easy enough to model the equation.
