fuzz pedal low output problem
Started by deadtemple, August 15, 2016, 11:34:46 AM
deadtemple
Hello everyone,
I tried to build a fuzz pedal t and have experienced some issues with it, which is
the fact that, it's fine when it's bypassed, but when I switch it on, even though the LED turns on, the output is really low.
I have to crank up my 60W amp to 90% percent to hear the pedal working.
Even though I'm fairly new to pedal building, I managed to succeed in completing even more complicated projects before.
I checked the connectivity with a multimeter and couldn't find any malfunctioning components. I double checked if the wiring is correct like 100 times.
I just don't know where to take it from here, any ideas what to do?
link to the project:
http://www.ghosteffects.co.uk/pdf/si_pep_box_pcb_guide.pdf
Photos:
Welcome to the forum!
Sadly it is hard to begin to guess without knowing what is in there. The build-doc you linked doesn't really show the circuit. That website doesn't seem to have the circuit. I went by what it is "based on", and found this:
http://forum.musikding.de/cpg/albums/userpics/16602/germaniumpepbox.png
Find the 9V rail. It must be NEGative 9V measured to ground (jack shells). (Which means you can't power this box with other boxes on a common +9V supply.)
The Bases of both Q1 and Q2 should be near 0.1V-0.2V.
The Collectors of both Q1 and Q2 should be above 1V and below 8V. (This type bias is not very precise, so you may have to trim.)
deadtemple
Thank for your prompt response and help.
However, I dont fully undersand what you've said.
How should i power the circuit then?
I tried plug a 9V battery to a dedicated battery clip
But it clearly doesn't work.
Please help :)
balkanizeyou
From the build document:
QuoteThe circuit is negative ground and can be powered with a 9v battery or a 9v DC adaptor with a negative tip.
So the circuit is "normal" negative ground & you don't need to worry about that part. The wiring from the build document should work, although it's kinda misleading (the labels "+9V" and "-9V" suggest a bipolar supply - it should be +9V and 0V or GND).
What transistors do you use? Did you check their pinout? And please check both transistors' voltages and see if they match Paul's suggestions.
