man.....i'm in a soldering slump
Started by plexi12000, August 17, 2016, 02:21:31 PM
plexi12000
i dont know what the heck my problem is.  last three projects have tanked.  no components out of place....but i guess just "bad" soldering?
one, i totally redid and got it working, got sound.....but not "working" properly.  i took meticulous time to get shiny solder joints too.  wTf?!   :icon_lol:
i did get some new solder before all this.....i had kester brand before. maybe i shoulda stayed w/ kester.  i don't believe my iron is too hot.  i have a good weller wlc 100. and i usually have it between "3 1/4" and "3 1/2". Seems to be plenty of heat.  Grrrr.      anyone else ever get into this sort of funk?
jimilee
Yep, my last 2 and another I never did get working. I did get one of the last 2 working finally. I got a second set of eyes on it and they saw it right away.
Sent from my iPhone using Tapatalk
Yep Plexi I have lots of funky junk going on. Soldering iron, transcription from breadboard to pcb, switch wiring, forgetting to plug the guitar to input before testing envelope detector.
All kinda stuff.
Hemmel
I just call them "brain farts" and laugh them away.
Last one I had was cutting a 14/2 electric cable while having the wrong breaker off.
Let's just say that POOF scared the crip out of me.
But now I laugh about and know that I will be exceptionally careful when turning off breakers in the future.
Bââââ.
It can be shiny on top and totally un-stuck underneath.
Are the leads and pads DEAD clean? Can't solder to oxidation.
Good plan to pre-tin leads and pads separately so you can SEE the solder "WET" the raw metal surface, not just blob-up on oxide or gunk.
Electronics grade solder with rosin flux core?
thermionix
Quote from: plexi12000 on August 17, 2016, 02:21:31 PM
Kester is great and all, but in my experience 60/40 rosin core is 60/40 rosin core.  Radio Shack solder has never let me down.  63/37 has been fine too.  The only solder that has caused me any frustration is lead-free, I hate that stuff.  Did you by chance get some lead-free?
nickbungus
I've recently had this.  After a long glorious period of successful builds, I hit a massive slump where nothing worked.  I've had 3 go's at the Snow White Autowah!  (I have a working build now)/
To be honest I don't really feel out of it but I decided to go back to smaller builds again and work my way back up.  Seems to be doing the job.
To the extreme, I rock a mic like a vandal.
Light up a stage and wax a chump like a candle.
Quackzed
I regularly have bouts where everything I touch is gold and everything powers up and works right out of the gate.  These alternate with bouts where everything I touch turns to s***, nothing works, no matter how simple and "easy", and I can't seem to find the problem.
It happens.  Wish it didn't, but it does.  Fortunately, the one gives me hope that sees me safely through the other.  :icon_smile:
karbomusic
#9
Once I found a proper workflow, stuck to it and not get in a hurry my success rate went up quite a bit. Every time I have been bitten by a solder issue it appears to have been from being in a hurry and not taking the time at that time to confirm the joint.
Additionally, since I'm not a real production line, I have one of those all in one measuring tools which allows me to quickly do a final check on component values just before I place it on the board. I've found that 1 extra minute at build time = potentially hours of saved debugging time later.
Even though I've soldered in some form since I was about 8 years old (I'm 53 now), I still got a lot of value out of watching this entire series a few months back....
https://www.youtube.com/watch?v=vIT4ra6Mo0s&list=PL926EC0F1F93C1837
One other thing is to always be particularly aware if using a NOS part because their leads, are almost always gunked/tarnished in some way compared to new parts and if mixing the two the new parts create a false sense of security causing the NOS solder joint to be more likely to fail.
And finally a high magnification review using whatever you have (I use head gear and/or a USB microscope) once I'm done with the board, just before I throw it on the scope and start feeding it test signals.
It isn't like I don't have bad days but they surely went down exponentially once I started observing the above.
2 cents.
Quote from: Mark Hammer on August 18, 2016, 11:14:09 AM
Me too. I've been soldering since the late 1960s and I still have bad days. It's going to happen. Just expect it as a condition of life. I've been eating for a long time and I still get indigestion and gas sometimes. Shrug.   :icon_lol:
Another view: Life may be a walk in the park, but sometimes you still have to clean your shoes.
thermionix
Quote from: karbomusic on August 18, 2016, 11:17:34 AM
I always keep a little wad of #0000 steel wool and bits of fine sandpaper on the bench, and any component lead that isn't perfectly shiny, new or old, gets a quick wipedown.  Often followed by a shot of spray cleaner.  Well, that would be resistors, capacitors and such...not chips or anything with fragile leads.  And obviously you don't want to leave steel wool fibers behind that could cause shorts.
Quote from: thermionix on August 18, 2016, 03:19:04 PM
I always buff my etched PCBs with superfine steel wool, wipe 'em with liquid flux, and tin them before they have a chance to tarnish.  I'm sure there are places where boards don't tarnish with air exposure during the first week, but there are probably more places where what was shiny Monday morning isn't by Tuesday morning.  Happily, solder doesn't oxidize nearly as fast as bare copper, so tinned boards can be drilled and safely put away for another free evening or weekend when you finally have time to get back to the circuit without having to worry about whether the joints will be cold on arrival.
LightSoundGeometry
any ideas on how to store solder to keep from going bad?
thermionix
Quote from: LightSoundGeometry on August 18, 2016, 03:48:37 PM
I don't think solder does go bad.  It will oxidize, but is still usable.  When you melt a metal, oxidization and other impurities tend to float to the surface as slag.  Sometimes this will result in a cloudy looking solder blob, but the bond is still good.  I recently used up some old solder that was very dull gray from oxidization, and it worked just fine.
LightSoundGeometry
Quote from: thermionix on August 18, 2016, 04:05:48 PM
I buy this and all I use
http://smallbear-electronics.mybigcommerce.com/solder-60-40-tin-lead-spool/
robthequiet
QuoteI don't think solder does go bad.  It will oxidize, but is still usable.  When you melt a metal, oxidization and other impurities tend to float to the surface as slag.  Sometimes this will result in a cloudy looking solder blob, but the bond is still good.  I recently used up some old solder that was very dull gray from oxidization, and it worked just fine.
Roger that. I'm using a spool that must be ~25 years old. I may not get that glassy shine but it's a good bond, usually. I always make sure I have a good mechanical connection before applying solder, so that components don't microscopically wiggle as solder is setting. Other than that, it's all about how you hold your mouth, a wise man once said.
I'm still using reels I musta bought in the late 1980s.
Not sure what could "go bad".
LightSoundGeometry
Quote from: PRR on August 18, 2016, 05:15:01 PM
maybe I am applying too much solder or you have one hell of a roll of solder in the basement !   :D
karbomusic
QuoteI always buff my etched PCBs with superfine steel wool, wipe 'em with liquid flux, and tin them before they have a chance to tarnish.  I'm sure there are places where boards don't tarnish with air exposure during the first week, but there are probably more places where what was shiny Monday morning isn't by Tuesday morning.
Good point. In my hands I swear it starts tarnishing within minutes. :D  I finally got tired of it and now hit them with a very thin coat of clear lacquer the moment I clean off the etchant and toner which lets me store them for a very long time. Usually, it's dry and can be handled within 120 seconds so I don't really have to wait for it to dry.
