Author Topic: Magnus Modulus-IC2 pin 4's connection to ground  (Read 513 times)
strungout
« on: August 21, 2016, 08:50:28 AM »
Hey,
I'm currently re-working the Magnus Modulus layout (on page 5 of 5) so it is more perfboard friendly, but I can figure out how IC2's pin 4 connects to ground... Someone help me out? BTW IC2 is upside down.
Thanks.
EDIT: Ah, nm just found it by looking at the PCB traces! Can be hard to see traces that go under components!
« Last Edit: August 21, 2016, 08:59:56 AM by strungout »
"Displaying my ignorance for the whole world to teach".
"Taste can be acquired, like knowledge. What you find bitter, or can't understand, now, you might appreciate later. If you keep trying".
strungout
Re: Magnus Modulus-IC2 pin 4's connection to ground
« Reply #1 on: August 21, 2016, 10:57:39 AM »
I have another question, which is the rate LED? D2?
blackieNYC
« Reply #2 on: August 23, 2016, 01:38:05 PM »
I don't see a designation on the schematic, but it's the one hanging off the oscillator output where it connects to pin 6.  All other LEDS are implied to be on the 2nd pole of the "toggles" in the schematic. Built one long ago. It's great.  I don't think I got the fet tremolo to work right so I did it some other way.
Thing Modulator, Magnus Modulus +,Meathead, 4049er,Great Destroyer,Scrambler+, para EQ, Azabache, two-loop mix/blend, Slow Gear, Phase Royal, Escobedo PWM, Uglyface, Jawari,Corruptor,Tri-Vibe,Battery Warmers
