tube screamer issues
Started by JebemMajke, August 28, 2016, 06:01:42 PM
JebemMajke
So i've built a ts808 using tonepad schematic, as I;ve did many times before.
http://www.tonepad.com/getFile.asp?id=81
For some reason my tone pot is having some issues, whenever i turn it to max or lowest there is no sound what so ever.
voltages
8 8.93
7 7.93
6 1.5
5 4.27
4 0
3 4.47
2 4.48
1 4.53
any ideas?
Section two of your opamp (pins 5,6,7) show something wrong.
Pin 5 is at what I suppose the bias voltage to be, but pin 6 should be the same voltage, and so should pin 7. It is likely that something is holding pin 6 down. Check your circuit to see if there is a soldering or parts placement error around pin 6.
jimilee
Is the tone pot shorting out on something next to it when you twist it, or is it a bad pot?
Sent from my iPhone using Tapatalk
JebemMajke
@ Jimlee
Bad pot was my first thought, so I've tried 3 different pots, and results were the same.
@ R.G.
I'll check pin 6. Thnx
JebemMajke
out of interest, what type of cap was it?
JebemMajke
Film type.
Should have been tant, but hell.
Film box, wima it is now.
