wiring a tube just for light
Started by Dimitree, October 14, 2016, 11:25:09 AM
M.A.P
If you want to use tubes as a light source you have to use the right ones. EL84 won't work properly.
Get one of these: http://www.b-kainka.de/bastel25.htm
I already got one but never tested it. Still searching for a transformer with 12V 10,5A :icon_lol:
And back to topic: Always connect the voltage to the heater that is specified in the datasheet for normal use. For use as a light source you could use less voltage but I would never use more as specified. As already mentioned connect two EL84 in row to divide the voltage to 6V per tube and everything should work fine.
Greetings from Germany
Marcus
Dimitree
ok I put 6.3V DC on pin 4,5 and now it glows :)
experiment ended.
digi2t
#22
:icon_biggrin:
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
nosamiam
