Help with AION Stratus project
Started by FastEdTex, November 18, 2016, 11:25:48 PM
FastEdTex
Hobbyist working on a AION Stratus (TS) project. Stock build with no subs on values, (intentional that is)
Pedal powers up, get a signal in both bypass and effect. (sounds like slight clean boost)
Effect on, Volume works, tone seems to work - NO GAIN Change with the pot.
I have the "Bright" Mod with SPDT switch - switch works after soldering, firm clicks, continuity check shows it is working.
Same for the "Clipping" Mod switch - SPDT and continuity test shows it is working.
Clip switch and pot have no effect on the sound.
Anyone have experience with this effect?
PCB IN = 9.23 V
IC1
p1=4.48
p2=4.48
p3=4.48
p4=0.0
p5=4.48
p6=4.55
p7=4.48
p8=9.03
Q1
E=3.57
B=3.99
C=9.03
Q2
E=3.56
B=3.99
C=9.03
Which pot?
If the Drive pot does nothing, C4 R5 not really connected.
FastEdTex
Quote from: PRR on November 19, 2016, 12:22:08 AM
Which pot?
Yes, Drive Pot does nothing.
Guessing you have a short across your diodes/pot, which could explain every symptom.  Double (triple) check your jumper and diode placement. Very cool looking board.
FastEdTex
Quote from: EBK on November 19, 2016, 12:11:27 PM
Thanks Paul and Eric!
Re-flowed some solder on C4 and R5 (and a couple of other suspect joints) and checked jumper and diodes.
Working well now. Thanks for the input!
Eric,
It is a very nice "mod" laden TS PCB. Very good quality. Kevin at AION has some great PCB's at very good prices.
The IO PCB I had made. I hate wires and soldering the switch and jacks.
As you can see from the photo below, I made a mistake and had to run a jumper wire, but it works.
aion
Quote from: FastEdTex on November 19, 2016, 01:41:18 PM
Very nice! What kind of bypass are you doing there? What's Q3 doing?
FastEdTex
Quote from: aion on November 20, 2016, 07:55:54 AM
Answer to both, Going around Q3 which was intended to be reverse polarity protection. Didn't work as planned.
Since you're Excellent! AION Stratus PCB has all that on board, I just went around it.
I have since switched to a MOSFET P-channel to do that and it functions correctly on my next generation IO PCB.
Have it in my chain with the AION Refractor, into the clean channel they sound great.
