Transformer design calculator
Started by sajy_ho, November 28, 2016, 06:17:38 AM
sajy_ho
Hi guys, recently I've been busy winding transformers for guitar amps. I found it hard to do all the calculations manually every time, so I inserted all of my collected formulas into an Excel file and it became a nice calculator, I thought it might be handy for someone else:
https://www.dropbox.com/s/drerg1tygub06ww/Transformer%20Design.xlsx?dl=0
It is capable of calculating both power and output transformers, all you need is to follow the steps and it will give you the results...
Regards
Sajad
Life is too short for being regretful about it.
tubegeek
maartendh
Always wanted to wind my own, probably this will be of great help when I actually decide to do it -  thanks!
Maarten
sajy_ho
You're welcome;
It saved me a lot of time, hope it comes handy for you too.
It maybe seems a bit complicated at the first look but it's actually is a very simple calculator. Every box has it's own explanation, just hold the pointer on each box too see it and fill the box based on your requirements and available material, E.g. guitar or Hi-Fi, ...
