Madbean Current Lover 2015 - Clean (no effect) Signal Only
Started by brucer, December 06, 2016, 12:36:49 AM
brucer
Yes, the previous failure is definitely troubling.  That has me a little nervous about reboxing.  The DC jack when last boxed was plastic with a metal nut.
Quote from: brucer on January 01, 2017, 01:32:50 AM
Plastic DC jack is good.
Some more thoughts on how to be extra cautious:
Double check your stomp switch continuity in both positions before you wire it up again.  Also check for continuity between the terminals and the outside metal parts.
Double check your DC jack outputs with a power source, again before you wire it up again to make sure it works as you expect it to work.  Were you using the same power source for test rig and in box?
Consider wiring it up in the box, but removing it from the box before powering it up again to test (i.e., to get it all connected with the wire lengths you want).
brucer
Good tips Eric.  Thanks for that.  I'll follow it step-wise.  Re power for testing rig and boxed effect: yes, both were powered by a Voodoo Lab ISO-5 9v outlet.
