Aion Refractor Klon Clone help
Started by broomhandle, December 30, 2016, 12:25:21 PM
broomhandle
yeah just saw that... only one jack is backwards... thank you for pointing that out. sometimes when I wire these i have kids yelling in the background to help me concentrate....
Quote from: broomhandle on January 03, 2017, 11:41:45 AM
I'd have to take another look, but I thought BOTH were backwards....
On the left jack (input jack), it should be GREEN to SLEEVE, GRAY to TIP.
On the right jack (output jack), it should be WHITE to TIP, SLEEVE unconnected.
broomhandle
cool thank you, I will double check when I get a moment...
banjerpickin
Quote from: EBK on January 03, 2017, 11:48:31 AM
Seconded, they are both backwards.  I'll bet that makes a difference in sound getting through!  ;D
Almost always testing Cunningham's law.
broomhandle
so,
not working...
wired correct, and I get a pop noise, as in a pattern. when i engage the ped, the led blinks low and same pop pattern.
I still can not get pass thru.
[url=https://flic.kr/p/QK8qQg]
[url=https://flic.kr/p/PDdKwS]
broomhandle
Check to see if your jacks are shorting against the enclosure or the stomp switch when your have a cord plugged into them.  It looks awfully close from the angle of the pics.
broomhandle
I had closed jacks before and it had the same issue. I feel it has to be a short. i will look again but I believe the jacks are not touching.
midwayfair
Quote from: broomhandle on January 05, 2017, 12:25:26 PM
Use your multimeter for continuity.
Electrons are really really tiny. Human eyes are no good for this task.
broomhandle
I would not know what to check... I am still new to this... I built 2 of aion's boards before, no problems... this one just dose not like me...
Quote from: broomhandle on January 05, 2017, 12:39:17 PM
Set your multimeter to continuity mode:
Then go around touching places that shouldn't be connected to each other.  If the multimeter makes a noise that scares the bejaysus out of you, then they're (unexpectedly) connected.  If you don't have a noisy setting like this, just put it on a resistance setting.  If you get zero, then you also have continuity.
I think you have the zener diode (part no. Z1) backwards on your board.  The side with the black stripe should be to the right.
I think Eric may have won the Internet this week.   ;D
broomhandle
this guy?
one should be the opposite way correct?
broomhandle
Quote from: broomhandle on January 05, 2017, 06:04:23 PM
so which part is backwards?
Z1.  Look at the picture of the board in the build docs and find it.  It's right up by the PGND pad I helped you find last time.  It is orange with a black line on one end.
broomhandle
#38
I see... crap. so prob can not re-use that right? pull it and get a new one? ugh...
I totally see now..  8)
Quote from: broomhandle on January 05, 2017, 06:32:00 PM
it may be still good.  Assuming it has been hanging in there continually shorting your power supply, it seems to have a lot of fight in it.   :icon_wink:
