Penfold Autowah
Started by Kipper4, January 08, 2017, 07:58:38 AM
rutabaga bob
Hey Fredrik!  That layout is sort-of what got this started - a desire for a perf version.  Any ideas on taming the weird frequency control?
Life is just a series of obstacles preventing you from taking a nap...
"I can't resist a filter" - Kipper
The controls are a bit fiddly to get it sounding ok. I had a play last night.
I'll have a play with some series resistors on the freq and resonance controls to try to make it more useable for guitar.
edit
I also tried swapping the bc109 for a 2n5088, sounds a bit better to my lame ears.
I stuck a 220k between the +9v rail and lug 3 of freq and it made more of the pot usable.
YMMV
Dont forget I'm using a B100k for freq pot.
So if you use the 50k freq  pot used in the schematic try a 100k series from +V rail.
I'm keeping the reso pot at low settings.
I know many people would as a matter of course anyway but, I soldered the unused lugs to the wiper lug too.
The changes have made it more useful now.
I need to do more testing though.
Thanks for the Tayda heads up by the way.
Some manufacturer must have had a bunch of new chips done then because when I bought mine there were not that many about. I ended up getting mine from Germany on ebay.
I might add a few to my shopping list next time I do Tayda shopping.
rutabaga bob
Okay, Rich...I'll make note of your tweaks.  Don't have the chips as yet.  I think Fredrik has a note on his about using a BC108 in place of a 109c.
Ooops did I mention I'm using 250k B pot for Resonance.
I tried several R values between pin4 of lm13700 and the resonance pot.
The one that works best for me is a 1K series.
rutabaga bob
The rez pot is spec'd at 250k...
Don't sweat about the BC109. It's only a buffer for the envelope follower, so it doesn't affect the audio directly. Anything would work there is my guess - BC547, 2N3904, whatever - the common stuff. It's only a BC109 because of its era, in the same way the default op-amp used to be the 741 (and is now probably the TL072).
Also, looking at the schematic again - what the hell was he thinking with that S1 switch for "bypass"?! Whack the filter up to some high frequency and that's "as good as bypassed", right? I doubt anyone would agree this side of 1995. It was cheap is about the best that can be said about it...
Tom
rutabaga bob
Rich...any updates?  Got this all finalized?
No I've been a bit busy with other stuff.
It works but its the devils own job to get it to wah nicely as yet.
How's yours?
rutabaga bob
Built, but no cash for chips at present.
