Weener Wah 2016 MadBean Peadals ISSUES
Started by spoontex, January 19, 2017, 10:00:02 AM
spoontex
Hi,
I've just build the Wenner Wah 2016, and I have some issues. When the effect is on the Wah is very subtle and I have a volumen drop. I revised the circuit many times and I have no idea... You can help me?
I've used BC239B instead BC109
http://www.madbeanpedals.com/projects/WeenerWah/WeenerWah2016.pdf
https://vimeo.com/200181550
http://es.tinypic.com/r/11vgmm1/9
Thanks.
spoontex
Sorry, these are the readings:
Q1
E= 7.82V
B= 0.581V
C= 0.03V
Q2
E= 9.79V
B= 1.76V
C= 1.21V
D1
+= 10.07V
-= 9.90V
Is normal that the collector of Q1 dosen't have any voltage?
thermionix
No, you're either reading them backwards or they're installed backwards.
spoontex
Yes... I put the transistors wrong.... a big mistake...
thanks!!
spoontex
Okey,
I've change the transistors with some BC109B with 220 to 260 hfe. And I raise R7 to 68k. But the wah sounds strange... It's hard to explain. I upload an audio file.
https://soundcloud.com/david-rotger-573523264/weener
thanks.
