Oddball chip
Started by Mark Hammer, January 22, 2017, 06:33:41 PM
I picked up a couple of old Dukane  PA mixers today, primarily because the price was right ($20 each) and they're sturdy 1U rack chassis already machined for 10 pots.  So, prime real estate for something else when I have time.
The mic preamps have input transformers.  The mixer uses 741s ( :icon_eek: ).  But the interesting part is that the two mic preamps use an NE5533.  That's right.  NOT a 5534 or 5532 but a 5533.  It's  an externally-compensated 14-pin dual op-mp.  I was hoping it  might have the same pinout as a 4739, to accommodate all those Craig Anderton classics, but the pinout is simply incompatible with anything else I've ever seen.
Op-amp A -  pins 1, 2, and 12.  Op-amp B - pins 6, 7,and 10.
Weird, huh?  If you're aware of anything else with the same pinout, you're my hero.
Just checked and I have one of those 5533's, must have purchased in the 80's, as well found a couple 4136's in the same drawer.
dave
Dead bug mounting. Put in what you like.
anotherjim
LM747. Which is a dual 741 - so extra pins are offset not comp'. Still active but not in DIP.
OP04 same pinout - also internal comp'.
armillary
R.G. I never stop learning new things from you. Thanks! I didn't know dead bug was an official term, but quickly found this:
https://workmanship.nasa.gov/lib/insp/2%20books/links/sections/303_deadbugs.html
The only caveat I would add is that dead-bugging 14-pin chips is contra-indicated for use with 1590A enclosures!   :icon_lol: (I feel like I should have a long list of potential side-effects, like they do in those pharmaceutical commercials)
armillary
There once was a case with no clearance
a dead bug's legs caused interference
the engineer tread
to squash it instead
admiring the change in appearance.
The Electronic Packaging Handbook
edited by Glenn R. Blackwell
CRC Press, Nov 29, 1999
ISBN   1420049844, 9781420049848
Analog Devices, MT-100 TUTORIAL:
Breadboarding and Prototyping Techniques
http://www.analog.com/media/en/training-seminars/tutorials/MT-100.pdf
page 3
