Drain and Source exchangeble
Started by sbirkenstock, January 23, 2017, 12:40:24 PM
sbirkenstock
Hi Everybody,
seems like most or all Jfets have an exchangable Drain and Source.
I did try with 3 different ones (2N5457, J201, MPF102), and exchanging the Drain and Source did only very, very marginally change the CutOff (less than a 10th of a volt).
Also the Bias or drain voltage (10K Drain Resitance / 1,5K Source Resistance, on 9v, Gate grounded with 1M) did not change noticably exchanging them.
Can I assume that this true for all Jfets?
From theory that makes sense (because of the symetric built), just want to make sure!
Best regards,
Stephan
FiveseveN
Yup. As usually noted in the datasheet.
