What would cause death of a potentiometer
Started by cytt0rak, February 17, 2017, 09:29:05 AM
cytt0rak
Hello, I have built a pedal for friend of mine and its second time output pot is broken. I know they are not alphas, some no name chinese but I built many stuff with these and none of them broke yet. Am I just lucky or can a specific error after weeks of use kill it?
drummer4gc
Too much heat for too long when soldering it could significantly diminish the lifespan, particularly if they're cheapos.
Plexi
Too much heat, and sometimes the ears can loosen from the pot if it moves more.
That produce a bad/false lug/carbon track contact.
To you, buffered bypass sucks tone.
To me, it sucks my balls.
My money is on a bad solder joint plus mechanical stress.
cytt0rak
Quote from: drummer4gc on February 17, 2017, 09:32:25 AM
Quote from: Plexi on February 17, 2017, 09:37:48 AM
It could be true If it happened to years ago where I had bad mains type of soldering iron and with needle tip, I bought good soldering station with tips for soldering lugs,smt to increase efficiency.
Quote from: EBK on February 17, 2017, 10:24:23 AM
It could be but other pots on that pedal are not dead yet considering saturation pot is used more than output one. I use solid core wires to support components.
Quote from: cytt0rak
quote author=EBK link=topic=116837.msg1083354#msg1083354 date=1487345063]
[/quote]
I was thinking more along the lines of a bad solder joint on a wire leading to the pot in question, plus the pedal getting bumped around enough to break the connection.
cytt0rak
Quote from: EBK on February 17, 2017, 11:07:44 AM
Understood, I used a bit longer wires this time and tightened them that might take some stress off from wires and lugs. Thanks
anotherjim
Our usual carbon pots have low power handling. It is possible that for some reason significant current is going through that pot and burning out the track causing a dead spot, which could mean a fault in whatever else is connected, such as DC leakage on that other things input. If this output pot has it's wiper directly feeding the output (no cap or anything other than the bypass switch along the way), I would fit a resistor (maybe 1k?) in series to limit any such fault current.
cytt0rak
Quote from: anotherjim on February 17, 2017, 12:01:44 PM
That was what I have been thinking at first, wiper is directly feeding the output should I put a resistor between wiper lug and and 1/4 jack or like a clr for led in front of strip lug?
J0K3RX
Tell your friend to stop stepping on the output pot...  :icon_wink:
Quote from: J0K3RX on February 17, 2017, 12:19:10 PM
Good point.  That could do it too.
anotherjim
Yes, exactly like a CLR for a led.
But +1^, it is very tempting to turn a knob with a toe. In a perfect world, the knob would have a skirt that's just about clear of the case or pot nut so it doesn't rub, but would stop the pot shaft being pushed right down if stomped on. That's surprisingly hard to engineer when we can't choose an exact match between knob and pot. If the pot thread is too long to let the knob sit low, you could fit washers or spare nuts, assuming there's room behind the pot body.
pinkjimiphoton
too much current can smoke pots too. is your output cap leaking?
Slava Ukraini!
~Jack Darr
robthequiet
Ditto what Plexi said, the ears loosen up  -- factory spasm. Take that puppy out and inspect.
