Bit Commander bit better layout. Schematic?
Started by Elijah-Baley, March 08, 2017, 06:55:44 AM
Elijah-Baley
Hi guys.
My third octave fuzz: the Bit Commander is a multiple octave fuzz.
I'm working on this layout:
http://tagboardeffects.blogspot.it/2015/09/earthquaker-devices-bit-commander.html
It's verified, but there's a bit inaccuracy in my opinion.
Base1->Sub1->Down1->Up1->Level1->Ground
But, Base 1 is already on the board, connected to the ground, indeed. While the other pots are not. I wonder why.
I draw this and I guess it has some free spots for those wires:
What do you think?
PS Did someone find the schematic of this pedal? ???
Thank you!
antonis
Quote from: Elijah-Baley on March 08, 2017, 06:55:44 AM
Maybe to use Base1 as a GND reference point..
(only one wire from PCB to 4 pots..)
Elijah-Baley
In the end I connected the lugs 1 in chain. So the only ground wire is that on the board.
The electrolytic and the transformer take off some space, I have to find a way to squeeze it into a BB size box, perhaps I have to rewiring the pots with shorter wire.
The octave up effect is a bit weak. I used two random diodes 1N4148.
Weird we can't find the schametic. :o
Elijah-Baley
Elijah-Baley
Anyway, I just tested the circuit comparing it wiht the demo above. Works similar, the octave up depends from the overall settings.
antonis
Quote from: Elijah-Baley on March 08, 2017, 01:26:55 PM
Not weird at all..!!!
No person searching for "schAmEtic" should get any resonable result..  :icon_wink:
Elijah-Baley
After all, we can't get a layout without a schematic. :P
Elijah-Baley
zsound
Hi, i would like to know where i find the  component list of the bit commander? (capacitor type) Thanks
Elijah-Baley
Well, it is not a list but you can look the layout.
Schematic: http://guitar-fx-layouts.42897.x6.nabble.com/file/n22775/Circuit1.jpg
Layout page: http://tagboardeffects.blogspot.it/2015/09/earthquaker-devices-bit-commander.html
The capacitor are all almost electrolytic, the yellow rectangular are polyester. I bought the green cap from Tayda, those are small enough. The trasformer is the TM011, as the layout. The 386 is a quite available LM386N.
That's it.
Any question? Just ask! ;)
