tonepad Sinamp Volume issue
Started by maiko, March 13, 2017, 04:18:02 AM
maiko
so ive built the sansamp gt2 from tonepad and actually this is the 2nd one
This time im planning to use it as a preamp for my ggg TDA20x0
Question it is a very loud pedal i hardly past 8oclock on the volume and its already too loud.
any suggestion on how to lower the output.   it has a 5088 just before outpud.  can i adjust it there
any help would be appreciated.
https://imgv2-2-f.scribdassets.com/img/document/194292535/original/3894fea7ec/1487265476
try swapping the "vol" pot B100k with a log pot A100k. that might help shift the too loud point higher.
maiko
Yup ive tried this it actually helped alot and it placed my useable point to halfway but beyond
that its loud!! hahaha
antonis
Place a resistor in series with pot's upper lug..
maiko
you mean across lugs 1 and 2
so your suggesting i lower the pot value?    by half? so if 100k i solder also a 100k across 1 and 2?
not across, in-line with. try half the value of the pot, in series with the hot lug, so full volume will now be 33% lower.
really, you put a knob on that control, what difference does it make where you turn it to for comfortable listening levels?
maiko
ok i try to solder a 50k in series to lug 2
antonis
#7
Hot lug!!! - Upper lug!!! - Lug No 3!!! - The one that has the higher voltage!!!  :icon_cool:
Lug 2 goes to Op-Amp non-inerting input and the addition of 50k resistor will low down the GAIN of the NFB loop..  :icon_wink:
(and also the HPF cut-off frequency..)
maiko
