Plastic / esthetics: board printed over enclosure
Started by Plexi, March 21, 2017, 06:18:24 PM
Plexi
I like a lot how Spaceman pedals are presented.
Simple, distinctive and functional.
Anyone knows with which method/material they're made?
Plotter over pvc? or some plastic printed?
To you, buffered bypass sucks tone.
To me, it sucks my balls.
lukewarm58
I'm not certain of the exact method/material shown in your pictures, but it looks like it could be a laser engraveable acrylic.
There are lots of sources for the stuff... just to give you an idea, here's a link to the Inventables site (no affiliation):
https://www.inventables.com/technologies/black-on-bright-white-laserable-acrylic-sheet
Hope that helps.
Plexi
The acrylic recordable laser is what I thought at first glance.
But it's more like printing, and I can not see any relief/form letter, like the "bilayer" laser recordable acrylic.
It's what you mean to?
It's possible that the color layer be thinner?
Thanks for your help
thermionix
I'm gonna guess that's screen printed.  And maybe they have a machine that will do thin flat materials, but they can't fit a pedal enclosure in.  But then again I know nothing about screen printing.
It sure could be silk-screen.
And the world is full of T-shirt screen-frames which would fit thin sheet but not a big box (without major adjustment, which the screen-printer may not want to do for a few pedals).
stallik
It does look like silk screen but could also be directly digitally printed. UV curable inks will adhere well to these kind of products. Silk has a high setup cost for the screen which may make the process too expensive for a small run whereas direct printing can be used for a one off with no setup cost at all
Plexi
Yes... it seems to be direct print over pcv layers.
Let me know if I'm wrong: but in some photos there is a bit of relief, like a toner print.
I'll find the pic, that I don't remember where it was, and post it.
Plexi
Update!
I don't find the pick I was looking for, but, found another that solve my doubt partially:
http://gearguychris.com/wp-content/uploads/2012/01/spacemanIII1.jpg
If you make zoom over the pic, clearly the one of the left is bilayer laser print.
But the one of the right?
tonyharker
That looks like a material called traffolyte which is a multi-layered plastic sheet meant for engraving either by a revolving cutter or a laser. see https://en.wikipedia.org/wiki/Traffolyte and http://www.traffolytelabels.co.uk/
lukewarm58
QuoteIf you make zoom over the pic, clearly the one of the left is bilayer laser print.
I'm by no means an expert on this stuff, but when I look at that picture, I tend to think the one on the left was rotary engraved (thicker lettering, horizontal striations in the Roman numerals indicating a cutter not perfectly perpendicular to the material) and that the one on the right was laser engraved (finer lettering).
Plexi
I'd say those look printed on paper and dry mounted onto thin mdf.Just now saw those close-up pics....
Plexi
Quote from: EBK on March 22, 2017, 03:13:03 PM
Yes, I don't discard your observation.
I saw a few ones that looks like plotter over pvc.
