High gain practice amp to diy
Started by cytt0rak, March 24, 2017, 12:21:52 PM
cytt0rak
Hello great people of diystompboxes.com,
I've have learned main parts of pedal building now I want to expand in to amplifier business, I want to build a hybrid amp (tube preamp non starved plate, solid state power amp). Before that I'm looking for a amp that I can build without exposing myself to deadly voltages, have fun and change some parts to achieve different voicings. Thanks.
Elijah-Baley
Hi! Nice idea.
I don't know if you can find an high gain tube preamp, maybe a fet version preamp, mesa-soldano-diezel style. But then it is not an hybrid.
I know it is not your target, but maybe you can build an overdrive tube preamp and to use a pedal distortion.
What SS power amp you want to build?
Marcos - Munky
Just to be sure, the amp you're building now is solid state, right? How many watts are we talking about?
cytt0rak
Quote from: Elijah-Baley on March 24, 2017, 01:21:26 PM
Hi! Nice idea.
I could just build a normal tube preamp and use pedals yeah, problem starts within power amp section cooling, enclosure, power supply makes everything complicated. I have seen some builds with transformers but I'm not really experienced with them I would probably end up blowing the house right now. I have some wall warts from leftover computer gear like 15v 1A dc adapter. Maybe I could build ss power amp and tube preamp seperately.Thanks for the answers.
Quote from: Marcos - Munky on March 24, 2017, 02:35:49 PM
Sorry for my English I'm not good as its not my native language. I want to build a solid state high gain amp that can handle a 2x12 for both practice and test benching trying different ideas. I'll use the power amp section from this build and integrate it to a plexi like tube preamp with preamp clipping. I have been reading on tube stuff for a long time. Thanks for the answers.
Marcos - Munky
I think you can power a TDA2003-based amp with those dc adapters. If your 2x12 have 4 ohms impedance, you'll get around 6W of output, which is loud enough for practice but not loud enough for rehearsal. I don't know if you can use it with a 8 ohms speaker.
Since you're planning on use this power amp later with a tube preamp, I suggest you to build a 60W-80W power amp using a LM3886 or a TDA7294. But you'll need to build a power supply for these amps.
Also, be aware that even a tube preamp have deadly voltages, if you decide to build one.
sajy_ho
I had the same idea last year and I used a plexi-ish preamp(from AX84 Hi-Octane) in front of LM3886. It sounded good but not as good as a real tube amp with output tube section. After that I changed the tube preamp with a nicely designed solid state preamp (ROG Thunderbird); man it came to life!
I,ve played it in front of a group of friends and none of them believed it's not tube!
IMHO tube preamp is not a critical part of the tube sound and can easily been simulated by SS circuits; so don't bother and go for ROG Thunderbird :icon_biggrin:
Life is too short for being regretful about it.
maiko
heres mine
Tube 12au7 for preamp into a Equinox reverb then to a GGG tda20x0 power amp (TDA2050 is in mine)
I also included an effects loop just in case
I also made a circuit to delay the continuity between the amp and speakers to mute the dreaded turn on thump
this is actually pretty loud with a 4ohm speaker load but the output is halved when i hook up to a 8 ohm cab
