Looking to build low parts Jfet Buffer/Boost - need ideas?
Started by chumbox, March 25, 2017, 05:47:31 AM
chumbox
Hey All
I want to build an all in one Jfet buffer with a boost control. Ideally low parts count and wondering if there is a way it can be done with one Jfet that runs as a unity buffer but you can then dial boost on top of that? Any ideas, thoughts or reference schematics appreciated. Hoping to stick in a 1590A with a switch ultimately.
Thanks in advance!
Elijah-Baley
Buffer or booster?
Buffer = unity gain
booster= booster
build a fetzer and use a series resistor to ground from the 100k output so it only goes down to unity?
http://runoffgroove.com/fetzervalve.html
Elijah-Baley
Quote from: Kipper4 on March 25, 2017, 06:22:44 AM
I could wrong, but do you mean that with that mod the Fetzer it is not anymore an attenuator? And we can do this mod to any booster?
Elijah-Baley
chumbox
KarenColumbo
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
blackieNYC
Only the J201 version of the Fetzer has 13dB of boost.  that's plenty for "solo level" under the right amplifier circumstances. The other Fets aren't enough - see the bottom of the fetzer page.
Maybe the Omega would be better - more gain for driving the hell out of a dirt pedal.http://runoffgroove.com/omega.html
The Albert Kreuzer site looks cool.  But the Tillman preamp is only 3dB of gain IIRC.
Elijah-Baley
chumbox
Just stumbled across this schematic and it appears to run at unity when off and then become a boost when on by attaching the boost wiper, using similar to idea to Kippers without an volume pot at the end it appears.  Nice design.
Ben N
antonis
Quote from: chumbox on March 27, 2017, 01:00:04 AM
I agree but it definately isn't a low parts design for a single FET ...  :icon_wink:
antonis
Maybe I get something wrong but a buffer is a device which acts ONLY as impedance "isolator"...
If we use a booster (which adds gain) and lower it's output we have an amplified - attenuated signal in which we've kept Vin/Vout ratio to (almost) unity but we've already alter it's waveform..
(We shouldn't consider it "buffer" anymore..)
We can go much closer if we use a booster with variable gain (lowest setting to unity) taking in mind the restriction for relative low RD value (for low output impedance) and signal's phase reversal..
Or use an op-amp in non-inverting configuration..
