pull down resistor noise and what does do?
Started by preciousmolina666, March 25, 2017, 08:29:16 AM
preciousmolina666
if my pull down is 1M and input impedance resistor is also 1M versus no pull down and input impedance resistor 500k, which is less noise?
what does pull down do resistor?
I hate noise...
If you only listen with NOTHING connected, your question may matter.
Usually we have a SOMETHING connected. Guitar, pedal, microphone.... The impedance of that usually dominates the hiss. If it is under 100K, 50K, then a Meg or two hanging on, or not, does not matter.
tubegeek
Quote from: preciousmolina666 on March 25, 2017, 08:29:16 AM
It prevents having a "pop" due to differing DC levels when connecting and disconnecting.
antonis
Quote from: tubegeek on March 26, 2017, 12:03:28 PM
True but only if connected signal is also at 0 V DC..
(i.e. AC coupled output or the moment crossing the X axis..)
EATyourGuitar
Quote from: antonis on March 28, 2017, 05:43:09 AM
if you put them on the input and the output of each pedal then everything will be 0v
:icon_cool:
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
