"Frankenstein'ed" circuit has ground problem(s). Please help, if you can
Started by KarenColumbo, April 10, 2017, 01:04:01 PM
KarenColumbo
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
KarenColumbo
Quote from: Kipper4 on April 16, 2017, 05:20:50 AM
here in the rog schematic.
http://runoffgroove.com/ubescreamer.html
Ah. sorry! Yeah, I omitted this stage completely :) You suggested several times to put the EQ stage before the drive stage, so I did - and it's much more efficient this way. I only took U1B, U1C and U1E of the ROG schematic.
KarenColumbo
Here's V1.3. I put in a BMP-like passive EQ instead of the mid boost (thanks, Kip!), cranked up IC1B with an 270k resistor (should be >11 then), got rid of the "Bass Boost" switch (which killed all character of any guitar when activated) and settled with a 2n2 cap (C14). Any other value did seem to make things worse, omitting it, too.
This thing is excessively complicated, of course. But I think it sounds quite nice for a multi-stolen-circuit-bastard ;)
I also experimented with different diode/LED combinations: orange, red, green, blue, pink, UV, Schottky, Zener - and stuck with the original 914s.
samhay
Some thoughts regarding V1.3:
Your blend might work better if your two signals were not 180-ish degrees out of phase with each other.
You don't need Q3.
IC1B has quite low input impedance, so will load down your town stack.
KarenColumbo
Quote from: samhay on April 16, 2017, 08:37:11 AM
You don't need Q3.
Thanks, Sam!
I assume, I could configure IC1B as a non-inverting amp to get rid of the phase issue.
How would you eliminate Q3? Just omit it?
I'll have a read regarding impedance - I put IC1B in to avoid impedance issues - but I think I messed up :/
samhay
Yes - make IC1B non-inverting with a large-ish bias resistor. It can still be configured to have gain if you need it.
IC1A can easily drive the tone stack, so yes, just omit it.
KarenColumbo
Am I on the right track with this little snippet?
I know, this must be extremely basic - but that's something to get a hold on to :)
samhay
Yes-ish.
You want to connect R1 and Rcomp to half supply. Actually, you don't need Rcomp here and can jumper this.
Instead of connecting R1 to Vb, you can alternatively add a series capacitor and then connect to ground (or Vb or V+).
KarenColumbo
Gentlemen, thank you very much for your invaluable input! I feel, it's time to break this project down into the respective building blocks and have a long good read about issues like biasing, virtual ground, impedance and general opamp structures.  :icon_cool:
