where to get this strange pot?
Started by deadastronaut, April 11, 2017, 07:37:59 AM
hi guys,
i recently got an old ART FXR.
which is in need of a little TLC...
ive been trying to find one of these pots. (its not a rotary encoder as it behaves as a normal turn pot)
it has 7 prongs on it (pcb mount) as you can see in the pics.
any idea where i can get one, ????
cheers in advance..
slashandburn
I know a guy who knows a guy that sells all sorts of weird pot, if you're really struggling?  ;)
Anyway, more seriously, RS Online have a limited selection of 6 and 7 pin efforts that almost fit the bill?
https://uk.rs-online.com/mobile/p/potentiometers/8517474/
Edit: Ah bugger. Back order. My bad.
cheers iain, thats close... 8)
the 2 pcb mounts are in the middle/sides though..
Check the datasheet for that part from that RS Online link.  It comes in different configurations, and the datasheet tells you how the part number code works so you can change a letter or two to get the part number you need.
slashandburn
The one I linked is the Bourns"PTV Series", I think you're after the Bourns PTT series, or equivalent. It seems to have pub mounts on the rear. Where to get it though I've no idea.   ???
I like pub mounts.. :D
cheers man , great info, i,ll have a nose about..
why has it 7 jugs?..when its just a main vol out,,...hmmmm..
Quotewhy has it 7 jugs?
main volume out, stereo?
blackieNYC
Must be stereo. If you must, you might find a small enough pot to allow for off-board wiring.
http://www.allelectronics.com/item/apd-100k/100k-audio-taper-dual-pot-pc-mount/1.html
edit, this should do yes?
blackie, yes theres enough room for a dual 16mm too..
what would the wiring be though?...6 lugs, 7 wires?..
cheers
Those should work.  Although these have 7pins, only 6 (possibly 5, depending on model number) are connected to anything inside the pot.  They're essentially dual gang pots with the terminals lined up.  Most common pinout seems to be 1A 1B 2B 2A 3B 3A NC.  I believe that, as oriented in your pictures the leftmost pin would be the dummy pin (NC).  I could be wrong though...
Ok..nice one,
ive emailed that shop link, to see if thry ship to uk...
if not a 16mm dual will have to do..
I believe that they will ship to you.  All Electronics is a cool company.  I've purchased stuff from them before.  They buy up surplus parts of all kinds and resell them fairly cheaply.  If you dig through their site, you may find some interesting and unusual items that you can't find elsewhere.
Fender3D
They look like ALPS pots.
Mouser or RS...
Just check out the pinouts
anotherjim
7th pin could be a metal screen plate between 2 control wafers?
Quote from: anotherjim on April 11, 2017, 04:38:46 PM
Sounds too expensive for something they were just planning to call Dummy Pin in the specs.  :icon_wink:
anotherjim
Quote from: EBK on April 11, 2017, 06:17:53 PM
Well, there go the crosstalk spec's ;)
update, in the true spirit of DIY,
i used thermo plastic to remake the shaft, ...works great..
thermo plastic is my new best friend ..ive used it for all sorts of stuff.. 8) 8) 8)
this gear..
https://www.youtube.com/watch?v=ZQSPAUkHHJ4
Quotethermo plastic is my new best friend ..ive used it for all sorts of stuff.. 8) 8) 8)
just ordered some! thanks for the "hot" tip...   ::)
