wait... CD 2399?
Started by pinkjimiphoton, April 19, 2017, 10:02:01 PM
pinkjimiphoton
never heard of this one before, but it's in a little ammoon nano delay i picked up...
appears to be a DIFFERENT 2399,  sold as a reverb surround processor. it sounds great in the little nano pedal.. everything is smd in it, but the chip is full size
http://www.datasheetspdf.com/PDF/CD2399/808236/4
Slava Ukraini!
~Jack Darr
blackieNYC
I call BS on the "surround" and "reverb".  Sure, in a Karaoke bar it's called reverb. Same old 2399 is my guess. (can't find an English data sheet)
pinkjimiphoton
i'm wondering if this is what all them buggy pt2399s really are.
the little delay sounds killer for what it is. they broke the mod/delay switch by overtightening the nut on it.. so the switch fell apart during shipping. this thing is only a little over half the length of a 1590a!
trying to get a refund/another unit. language barrier proves interesting.
"how bout refund you 5 dollars, you fix yourself"... if it wasn't SMD, yeah, i'd go for it. i may still, if i can find the proper switch. ;)
i'ma gonna look around and see if'n i can't find some of these somewhere, and get an english data sheet.
but i am betting they are chinese knockoffs.. cd probably means chinese delay or something. ;)
Slava Ukraini!
~Jack Darr
KarenColumbo
#3
I think this chinese datasheet is a one to one copy of the original (?).
http://html.alldatasheet.com/html-pdf/391581/PTC/PT2399/112/2/PT2399.html
I have a few of them (PT) here - could send you some - would take ages, though :)
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
anotherjim
Pin 6, the delay time timing resistor.
Princeton original doesn't show that 47nF cap across it. If a variable resistor, there is also a fixed resistor in series.
CD2399 echo application (lower scheme) shows 100nF in place of the 82nF that the Princeton scheme has.
Agung Kurniawan
Multiple gain stage followed by some active EQ is delicious.
maiko
Yup CD2399
I actually got a bunch of those and  build reboote delays and Equinox Reverb seems ok and never
had problems.    In the Philippines its sold at 65 pesos or about a $1.50 per piece.    Princetons are
about 150 so roughly 3bucks.
Honestly if they did not run out of the PTs i probably wouldnt even tried using the CDs ;D
