Easy Vibe questions
Started by bifbangpow, April 26, 2017, 07:39:08 PM
Cozybuilder
bifbangpow
Quote from: Ben Lyman on June 23, 2017, 08:08:22 PM
Appears to have 2 ground pads, take your pick or use both, top left corner and top right corner.
Input appears to be 2nd pad from top left.
Output appears to be 2nd pad from top right.
Anyone else see it that way?
This helps tremendously!  Thank you!
Keep on keepn on.
bifbangpow
Quote from: Marcos - Munky on April 26, 2017, 08:01:50 PM
If you use a DPDT switch, questions 1 and 2 have the same answer: http://www.geofex.com/article_folders/millenium/millen.htm. Or you can use a 3PDT, so you don't need to use the millenium bypass.
For question 3, you can use this wiring diagram.
I am still having a little trouble. Can you help me? I started a new thread with my voltage reading and my wiring layout.  I tried to do what you said.  Here's the thread
http://www.diystompboxes.com/smfforum/index.php?topic=118190.0
Keep on keepn on.
