Power Supply question
Started by lapsteelman, April 27, 2017, 10:30:40 AM
lapsteelman
I'm rebuilding my homemade pedal power supply brick.. It's nothing fancy.. just the usual 3 terminal regulator circuit.  It works fine but what always worries me is I used an AC wall wart to power it and it uses the same 2.1mm connector on the input as the outputs.. I have a tag on the 12 volt AC line to warn me, but I'm always worried that it could accidently get plugged into a pedal and fry it.
Does anyone know of a panel mount jack (and plug) that I could use that would prevent an accidental insertion? I tried a 2.5mm plug, but it still went into the standard power supply jack.
Hope this makes sense... If nothing else I'll just hardwire it
antonis
Red & Black cable, perhaps..??
GibsonGM
Why not change the AC input to something totally different, like a 1/8" mono PLUG?   No law against it.  Then use the standard barrel-type for power out.
lapsteelman
Quote from: GibsonGM on April 27, 2017, 12:15:13 PM
I thought about that... but the 1/8 jacks that I find aren't isolated from the enclosure, which I would need.
GibsonGM
Quote from: lapsteelman on April 27, 2017, 12:30:22 PM
There must be SOME type that is isolated...somewhere....?    You really could use any style of plug, as long as it's different....like you said, go bigger, get a huge one (over 3mm) something like that...
You could get something completely over the top like this:
Same panel cut-out as an XLR chassis connector.
I've used little Molex connectors as they are unique, reliable and cheap. Need a two pin, male panel mount and a two pin female line connector.
The two types of pins you need are sold separately  as are the connectors.
http://dkc3.digikey.com/PDF/CA2011/P0226.pdf
Two line just so you know what i'm refering to.
dave
TejfolvonDanone
Jack is not a good option as plugging in/out may have a temporary short between the two terminals.
...and have a marvelous day.
GibsonGM
Quote from: TejfolvonDanone on April 27, 2017, 06:11:45 PM
Yeah, probably not the best option,  more an illustration of the many possibilities.    In the real world, I have a ton of computer power supply connectors and such...2 pin things.....I bet with some looking you could come up with something unique.
I do like the "bigger size barrel connector" idea, something you cannot insert the wrong plug into.
Is there such a thing as a panel-mount male power connector?
One way to do it would be to put a *female* inline connector on the 12V AC, and then you wouldn't be able to plug it into the pedals, since they're female too. But you'd need a male plug on the power brick. Maybe that could be hanging out on a wire too. Maybe that just moves the problem to connecting the AC to the power brick outputs!
like these:
HTH,
Tom
