4 knob vintage EHX Memory Man issues, calibration, whine
Started by acobberson, May 12, 2017, 07:37:02 AM
acobberson
I picked up an old 4 knob DMM with the SAD1024 chips. It is the blue and red version with squelch control.
Anyway, not to beat a dead horse, but... (and I know this is talked about in other threads but I didn't find any voltage readings in the other threads.)
The issues I have are that I am getting no delay and am having some high pitch whine. I of course suspected the bias trim pots, but regardless of where I set the bias control the high pitch remains constant and I get no delay response.
Here is what I have done so far:
Level control effects overall level: working properly
Blend control goes from good signal (CCW) to no signal (CW): this suggests a problem in the delay line
checked DC voltage from power source (24V)
checked DC voltage from 2n6290         (15V)
Audio probed IC3 opamp (the one feeding into the first BBD): signal is good
Unfortunately I have no scope, so I removed all SAD1024s, then placed the first one into IC4 position. I probed the outputs and found the high pitch was there. Tried to adjust bias and gain. Obviously I can cut it out with the gain control, but not without losing signal, and like I said the bias control does nothing to affect the whine. Also, I get no delay on the outputs, so I of course suspected a bad SAD1024. So I replaced it with one of the other SAD1024s and got the same result. One by one, I put the chips back in and tested the outputs but it all remains the same. Frustrating.
However, when I adjust the delay control I do get a "warble" from the output of the BBD. This would suggest that the Delay pot is passing signal from the 4047 clock, right?
So I read voltages of the BBD chips and got what seemed to be decent readings.
(chips IC4, IC5, IC7, IC8 respectively, readings in V)
pin   voltage                           pin       voltage
1    0V (all)                             16       0V (all)
2     2.8, 5.2, 2.8, 4.4              15       4.8, 5.3, 3.5, 4.4
3     7.4 (all)                           14       7.4 (all)
4     .4, 0, .1, 0                       13       0V (all)
5     4.5, 4, 5, 4.5                   12       5.6, 5.7, 5.5, 5.3
6     4.5, 4, 5, 4.5                   11       5.6, 5.7, 5.5, 5.3
7      13.7 (all)                        10       7.4 (all)
8      7.4 (all)                          9         13.6 (all)
So my questions are:
Could a BBD chip be fried and still give decent voltage readings?
What other issues could cause loss of delay? At this point, even with the whine present I would like to confirm the BBDs are functioning.
Any ideas or insight into this is welcome!
acobberson
I should probably also mention that the pedal was modded from the internal transformer to DC power jack.
The DC jack GND is going to GND and the + power is wired to the positive side of the bridge rectifier.
I understand that the transformer stepped power down from 110V to 24VAC, then the bridge rectifier converted to 24VDC... so it seems these connections are correct, right?
marlin
Hi,
I have the same issue with a whining unit, 4 knob version, it comes when turning up the delay to about half. Did you get further in this topic?
Scruffie
Quote from: marlin on March 24, 2018, 09:07:27 PM
Hi,
So the delay works but just whines? There's a 1k trimmer in there, unless you have a scope, probe the middle pin with an audio probe at the longest delay setting and adjust it for the least whine.
marlin
Quote from: Scruffie on March 24, 2018, 10:22:13 PM
Hi,
Hi and thanks, yes it works it's only the whining that is the issue. I am uncertain of which trimmer you refer to, there are 8 trimmers accessible from the back of the board. Do you know which one by hand? I attached a picture of my board, EH 1307A.
Scruffie
marlin
chuckd666
A job well done. I was going to suggest your power supply might be causing whine.
marlin
Quote from: chuckd666 on March 25, 2018, 07:27:13 AM
Hi and thanks! I actually replaced the two electrolytes in the power section for fresh ones that has the same size and look, whine was still there. What Would you suggest to improve it?
