Help: Hum but not when trem is engaged.
Started by master_wiggins, May 18, 2017, 04:39:53 PM
master_wiggins
Hi,
I'm hoping you can help me, I've been building pedals (from kits) for a a few years (but would still consider myself a beginner).  I have just got to the testing stage with my latest pedal and have come across a problem which I just don't understand.
The pedal is basically an A/B/Y  / loop to go at the centre of by pedal board with a few additions.  My main guitar has a piezo bridge pickup and this pedal sends the piezo signal through one effects loop and the main signal through another loop (actually 2 loops, but that's not relivant to my problem) then they both come back to the A/B switch and then out to the amp.  For the 'Y' switch I have a blender circuit and boost (both built from kits by Fuzz Dog).  Also on the main loop I stuck in an EA tremolo for good measure.
My problem is that when I try the 'Y' circuit I get a really noticeable hum.  I am fairly sure that it is coming from the boost not the blend circuit as I used the blend circuit in a previous pedal.  But here is the weird bit that I don't understand; when I turn on the tremolo the hum just disappears.  I don't understand because these circuits shouldn't have any effect on each other.
So just to clarify:
(Piezo out via EQ pedal) mixed with (humbucker out via distortion pedal) into boost - hum
(Piezo out via EQ pedal) mixed with (humbucker out via distortion pedal and EA trem) into boost - no hum
Anyone have any idea what could be going on here?
David
Ps.  If you'll excuse my shamefully messy wiring I'll post some photos below.
antonis
Nice tomato & pesto sauce spaghetti...!!!  :icon_biggrin:
(it's almost lunch time here..)  :icon_redface:
Don't know much about piezo pickups but, if you use "common" PS for all your pedals (daisy-chain), your tremolo has a 50/60 Hz RC filter in it's individual circuit..
P.S.
Re-arrange that spaghetti and embellish it with some low frequency decoupling caps..
as someone much smarter than me once said:
Quote:icon_eek:
master_wiggins
Thanks Antonis,
So would it make sense to try adding a filter to the power supply of the boost cercuit?
Something like this perhaps? :
http://shop.pedalparts.co.uk/Hum_Stop_-_power_supply_hum_reducer/p847124_6807259.aspx
antonis
It should be a good idea to place one on every individual circuit..
(if already doesn't exist..)
I don't suggest "one-for-all" for many reasons..
(one of them is the need for a very small series resistor, to avoid high voltage drop due to sum of currents, leading to a big electro capacitor value..)
Note that, you may avoid each circuit's hum but not necessarily the hum due to ground loops..
