St George Amp tremolo not working
Started by suryabeep, July 19, 2017, 12:50:22 PM
suryabeep
Hi everyone,
I'm thinking about getting a St George combo amp I found on my local CL for $100. It's made in the 60's in Los Angeles, but the owner says the Tremolo doesn't work. Is this an easy fix? Is it worth it? There's not a lot of info about these amps out there, so I figured I'd ask you folks. Sorry if this isn't the right place to post, but I don't know where else to ask.
Still in the process of learning, so bear with me if I ask dumb questions :P
thermionix
Tremolo is usually an easy fix.  Bad tube, bad cap, in the case of many Fenders bad optoisolator.  Never heard of St George amps.  Can you find a schematic for it?  In any case, if the amp sounds good, it's worth $100 even with no trem.  Be prepared to do a cap job on it, remove ground cap(s), and add a 3-prong AC cord.
suryabeep
I can't find any schematic for it, but the owner posted some pics on CL. Is a cap job difficult to do, or would I be better off taking it to a tech?
Is it your plan in life to be an amplifier technician?
If so, this is a clean place to start, but it may need a LOT more work before it will gig reliably.
While there is some mystique about the Massey amps, they seem to have been made as low-price shelf fillers, for buyers who could not afford Fender. Meaning there is not enough up-side on this to justify a paid technician. I'd do it, if it was here, if you paid me a lot more than it is honestly worth.
Eyeballing your picture, the can-cap and the two "Black Beauties" should IMHO be replaced sooner rather than later (when they fry a tube). The far-right black cap with red end is probably shot (this could be your immediate problem as it appears to bump the gain of the trem oscillator). There will be more.
Fender3D
Quote from: PRR on July 20, 2017, 11:57:33 PM
...Eyeballing your picture...
A few cents more, and you'll replace remaining resistors, caps and diode, too...
thermionix
I'd start with just the electrolytics and see where I am from there.  There were two series of Sprague "black beauties" (to the best of my understanding) and the later ones are much more reliable, like orange drops - poly-whatever film, with the earlier ones being paper and foil, same as "bumblebees" but with different printing.
I ended up spending some time last night reading about Ray Massie.  Interesting.  Apparently he worked with Leo in the late 40s, then Rickenbacker for a while, before starting Massie Electronics.  St George was a music shop that contracted Massie to build some amps for them.  People seem to like them, though they don't sell for much money.
Chassis pictured looks well-made, but only a few watts.  Probably a good recording amp.
