Need a long skinny enclosure, suggestions?
Started by exabrial, July 23, 2017, 01:53:55 PM
exabrial
Hey guys, I'm building a MIDI controller using an Arduino. I'd like to have 4 stomp switches ideally, but I could get away with 3. I've built a two-switch unit using a 1590a (code is here: https://github.com/exabrial/midi-stomper).
Anyway, I'm looking for a long (5"-8") x skinny (1.5"-2")^2 enclosure to house this. Any ideas? I've seen "true bypass pedalboard controllers" that are in a long skinny housing but haven't found an OEM for them.
Thanks for any help, greatly appreciated
xorophone
How about a Hammond 1032L? It might not fit your size specifications perfectly, but it's pretty cheap if you buy it from a chinese manufacturer. Under $20 on AliExpress.
Edit: Only $12.75 on smallbear, so if you're in the US, that's probably the best place to buy it.
http://smallbear-electronics.mybigcommerce.com/1032l-super-looper/
FUZZZZzzzz
What about 2nd hand amp channel switches. Come in different sizes. Cheap and predrilled. I had this H&K one small with four dpdt switches.
akc1973
Quote from: exabrial on July 23, 2017, 01:53:55 PM
http://www.geofex.com/Article_Folders/steelstud/steelstud.htm
Builds: Bazz Fuss, Orange Squeezer, Omega, Green Ringer, Dist+, X-Fuzz
digi2t
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Quote from: digi2t on July 23, 2017, 10:08:11 PM
https://www.mammothelectronics.com/products/4s1032l-looper-enclosure
I bought one of those from them a while back for a programmable looper project with a total of 5 switches and it was great.
Hammond 1590BX2 is 254x70mm.  That's 10" by 23/4".  I used one for this:
There are a number of modem housings available on the surplus market.  Some of them would be an exact fit for your needs.
Alternatively, check out local music stores and 2nd hand sources for an "orphan" footswitch housing from an amp.  These days, more and more of them have 4 and more stompswitch holes.  Yesterday, I adapted a 4-switch  Marshall unit to accommodate 6 SPST momentaries in a zig-zag pattern, each having a mini phonejack immediately behind it.  Not only is it the right size, but it's sloped-front.
exabrial
You guys are great! So many good ideas here. Thank you!
digi2t
I forgot about Loop Masters!! :icon_evil:
They have several blank enclosure sizes to choose from. I've ordered one from them, the quality is excellent.
http://www.loop-master.com/blank-true-bypass-strip-enclosures-p-292.html
Dead End FX
smallbearelec
Yea, the 1032L "Super Looper" is good. Still more:
Hammond 1411WU http://smallbear-electronics.mybigcommerce.com/enclosure-sheetmetal-hammond-1411wu/
Marshall-style Switch Box: http://smallbear-electronics.mybigcommerce.com/footswitch-boxes-drilled-and-undrilled/
The two-switch version would be wide enough and is available undrilled.
potul
Auminum, as far as I know.
http://www.hammondmfg.com/dwg18.htm
QuoteTwo Versions:
"1411" series - 0.04" thick aluminum (26 sizes)
"1412" series - 20 gauge steel (8 sizes).
