Big Muff Green Russian with Mids Control - debugging
Started by cub3rius, August 02, 2017, 11:41:21 AM
cub3rius
I need your help.
1.Name of the project: Big Muff Green Russian with Mids Control
2.Links to the source: https://effectslayouts.blogspot.com/2015/01/ehx-big-muff-green-russian.html
3.I used C549B transistors, 470pF capacitors instead of 500pF and B250k pot for Mids.
4.Problem: There's just clean sound of the bass guitar and loud high pitch noise. No fuzz at all.
5.So far I:
a. checked connections, resistors' and capacitors' codes
b. measured voltages:
Q1: C-7.49; B-0.62; E-0.047
Q2: C-7.42; B-0.62; E-0.049
Q3: C-7.30; B-0.58; E-0.011
Q4: C-7.68; B-0.96; E-0.386
Any ideas what might be wrong?
Plexi
To you, buffered bypass sucks tone.
To me, it sucks my balls.
Plexi
Plexi
cub3rius
Connections are fine, but I will double check the transistors.
cub3rius
You were right about the transistors. They were backwards. I feel stupid. :)
Now there's fuzz and all but I still get some high pitch noise...
Plexi
You're welcome  ;D
Quote from: cub3rius on August 02, 2017, 03:40:39 PM
I mean, not the connections: just the small shortcuts between them.
I'm 99% sure that the noise comes from that.
cub3rius
Quote from: Plexi on August 02, 2017, 07:32:44 PM
You're welcome  ;D
I've cleaned that and the noise is gone. :icon_eek:
You guys are golden.
Case closed.
Plexi
Quote from: cub3rius on August 02, 2017, 05:05:15 PM
No.  You feel educated!   :)     (And sorry, Pink Floyd, but you guys were sooo wrong...)
Plexi
Why you involve Pink Floyd on this?
Don't mess with PF...   >:(
;D
