Does a CD4053 CMOS Require a Buffer Before It?
Started by MarshallPlexi, August 12, 2017, 03:16:54 AM
MarshallPlexi
I read somewher on one of these forums that the CD4053 requires a buffer before it to protect it from static discharge on it's inputs. Is that a fact or is that forum misinformation?
For reference I would be building this exact setup:
http://www.geofex.com/article_folders/cd4053/cd4053.htm
anotherjim
Buffering will impose protection for the 4053, but maybe not essential. 4053, like most 4xxx series CMOS chips should have input and output protection built in. However, it can be a good idea, if possible, to insert some series resistance between the outside world and the chip pins. This will limit any fault causing potentially destructive current flow in the chips protection diodes. A 1k series resistor, will add some protection without altering normal function in most guitar circuits.
dschwartz
You also can use diodes to gnd and V+ for protection..
Tubes are overrated!!
http://www.simplifieramp.com
MarshallPlexi
Quote from: anotherjim on August 12, 2017, 04:32:11 AM
I like that idea!
MrStab
A buffer will also negate the impedance effect of the 2-3 bias resistors you'll need for each switch, and allow you to use lower values to achieve less switching pop
Sent from my Vodafone Smart ultra 6 using Tapatalk
Recovered guitar player.
Electronics manufacturer.
