PNP Transistor Projects
Started by stevics, August 14, 2017, 08:26:42 AM
stevics
I have inherited a number of Germanium PNP resistors. Are there any recomended projects for them. I have already built a Rangemaster Type Treble Boost. Types OC71, GET113, GET536. Cheers.
swever
Fuzz face is an obvious suggestion. I have just finished building a positive ground one with soviet nos low-hfe trannies I grabbed recently in a local flea market. I've designed a pcb layout for it and it seems to work fine. I may post it here if you are interested. It's not that there aren't enough ff layouts, i know. ;D Mine is different in that it allows to use a LARGE film input capacitor.
Also, I am working on a PNP version of zvex mastotron.
Fancy Lime
Hi Stevics,
the only area where Germanium PNPs are still used intensively are fuzzes. For several reasons, some of which are good, very good even, and some of which are stupid. "Hendrix had one" is not a good reason for building something for yourself or a fried, imho. But it can be a very lucrative reason for building something for sale. If I had your "problem" of being stuck with a bunch of Ge PNP transistors, I would search the internet for "Germanium PNP Fuzz" and spend a long time reading the hundreds of pages on this topic.
In either case, I would suggest that if you build something for practical applications, use a negative ground circuit. Any PNP fuzz can easily be re-designed to work that way. It allows you to use a common power supply with other stomp boxes. If you build it wth positive ground then you need to run it on battery or with its on supply (or together only with other positive ground circuits) because almost all modern pedals are negative ground. Contrary to what some people believe, you o not need a charge pump that converts + to - for this, just some knowledge on how a transistor works. See Jack Ormans article "Positive Power for the PNP Fuzzface" on AMZ-FX for how to do this.
Cheers,
Andy
stevics
Cheers swever and Andy
Swever, I would be interested in seing those layouts.
Andy. Thanks, makes good sense.
swever
#4
Here's the layout for toner transfer
swever
...and the components placement diagram
swever
You may want to adjust the 33?k resistor value to get about 4.5V at Q2 collector when the bias pot is at 12 o'clock. In my build 33k worked almost perfectly so I let it be - gives a great range.
One thing I need to mention is that with 500k volume pot I have been getting a big difference in brighness depending on voulme pot position - lower volume give darker sound. I have not yet found a solution for that,  really.  I changed the pot to 250k and it helped a bit, but there still is quite a difference. I am not sure if it has to do with the transistors or something else - I think my silicon ff does not have this "feature". Maybe a treble bleed cap shall help. I am yet to experiment with that. Maybe I should start enother thread on this topic...
Plexi
EQD Crimson Drive.
One of my favs
To you, buffered bypass sucks tone.
To me, it sucks my balls.
stevics
Quote from: swever on August 14, 2017, 09:35:52 AM
Hi I cant see any images or attachements not sure if I have a settings problem
Plexi
Quote from: stevics on August 14, 2017, 12:13:42 PM
Only the 'pure' people can see it... sorry. (¿)
On-topic: me neither  :icon_mrgreen:
swever
stevics
swever
