Can someone suggest me an overdrive pedal for solid state amps?
Started by seadi123, August 20, 2017, 07:39:45 PM
Resynthesis
Always had a soft spot for the EHX Hot Tubes. I've an original with a knackered transformer which I've never got around to fixing but recently bought the new version and still really like it on almost anything.
Chris S
Since no one else has, I'm going to recommend the valvecaster. Mainly because if ever I have to use my little solid state for some kind of performance I'll always bring it. The build is super easy and the sound is great.
nonoxxx
Do you tried a real screamer circuit ? the son of screamer if I remember correctly is unbuffered perhaps it's may be the cause of the weird sound.
antonis
Maybe a "mild" distortion pedal, like Guv'nor, with a booster (NOT necesserily MosFET, Sir...!!!) will make your job..
GibsonGM
Quote from: antonis on September 01, 2017, 06:23:34 AM
No, mosfet not required :)
IMO, what some others have said may be a good way to go:  a small tube-based preamp (Valvecaster? 18v?) and then you can overdrive THAT, if you are looking to capture some 'tube overdrive' sound!!   You could use a triode and have 2 gain stages - with the first overdriving the second by switch...
antonis
Well said Sir, but doesn't a tube overdrive "squandered" when driven by a solid state amp..??
