Author Topic: Purple Plexi 800 (LM386) hiss/squealing noise problem  (Read 631 times)
Plexi
« on: August 22, 2017, 09:46:59 AM »
Hi forum!
Yesterday I re-build in pcb (not breadboard) this distortion/od based around LM386.
When the 1k Gain knob is maxed, it made a squealing/hiss noise.
As I can read, there's a common problem in this schematic.
I hadn't this hiss when breadboarded it time ago, same LM386N3.
Is there any way to avoid that noise? Any experiencie?
What I'll try:
- Increase R3: increasing the "min" amount of gain before ground
- Increase C3? (From +9v to ground)
Another thing I don't get it; is if I swap to another LM386, N-4 in this case, it sounds really really bad and gated.
Voltage need of this particular design? I know it can works with more (>16)
I used on another pedals with 9v, and worked fine.
To you, buffered bypass suck tone.
To me, it suck my balls.
Re: Purple Plexi 800 (LM386) hiss/squealing noise problem
« Reply #1 on: August 22, 2017, 09:51:45 AM »
have you got a 386-1?
http://www.youtube.com/user/100roberthenry
http://deadastronaut.wix.com/index
^ SPACE PATROL FUZZ/ NANO-8 MIDI DRUMS /CHASM REVERB / TREMSHIFTER / FAZE FILTER/ABDUCTOR II DELAY pcb's + WAH LIGHT PLATES. and sausa
Plexi
« Reply #2 on: August 22, 2017, 09:53:56 AM »
I haven't  :-\
Should I try one, before mess around?
« Reply #3 on: August 22, 2017, 10:04:31 AM »
yeah i would....they are different
1 = 1/4 watt
3 = 1/2 watt
4 = 1. watt
Plexi
« Reply #4 on: August 22, 2017, 10:18:19 AM »
Sure.. know about that difference.
I'll try: maybe it's some kind of oscillation due the Watts.
Cozybuilder
« Reply #5 on: August 22, 2017, 10:31:16 AM »
I haven't studied the 386, so may be off base here. What I know is the gain of the 386 is adjusted by the relationship between pins 1 and 8, shorted gives a gain of 200, open is gain of 20. In addition, the gain set-up with the parallel R4 (470R) and 1K pot adjusts the amount of AC gain through cap C4. R3 gives a minimal resistance for attenuation. I suspect that you might have too high of gain with that particular chip, which suggests at least 2 ways to attack the problem.
1) The gain pot when fully CW gives 0 resistance to ground, thus shorting R4, so the effective RC on pins 1 & 8 is R3-C4 to ground. You might increase R3 slightly, or add a small amount of resistance to the wiper of the pot to ground.
2) Possibly reduce the gain of the LM386 by adding resistance between pins 1 and 8.
Plexi
« Reply #6 on: August 22, 2017, 11:18:08 AM »
Thanks Rob and Cozy
I was reading about the JRC386D suggested... and it suppose to be the equivalent of the LM386-1: both 1/4w (~250mW).
I think, like Rob supposed, it's a wattage feedback/oscillation.
I'll try the 386-1 before start to tweak around.
As someone says, it's almost a Krank Distortus Maximus.
But, they solve with better, consistent and useful solution: just go from pins 1-8-->100R (instead 10R)--->47uF---->ground
And boost/clean at the input.
If the problem persist with the 386-1... I'll follow that way.
Plexi
« Reply #7 on: August 22, 2017, 01:15:17 PM »
Update, problem solved!
That's work:
What I'll try:
R3 from 10R to 39R.
That's why I suppose the 100R are a solution on Distortus Maximus... at the end, the LM386 are pushed with the LPB1-kind of the front.
Plexi
« Reply #8 on: August 23, 2017, 11:27:07 PM »
Messing around LM386's google search, I found this similar version:
http://2.bp.blogspot.com/-xqH5Q9Q0XYw/TzOt99GqJlI/AAAAAAAAA5g/Ux6id6Ditx0/s1600/BlackMagic.bmp
It's strange how it uses 500R pot, and 1R resistor to ground.
If with 10R oscillates/squeals as crazy... with this method It'll squeal as a pork in mating season...
I'll breadboard and see. But, as Rob says,I believe it's the LM386 over saturated.
I'll wait for some LM386-1
« Last Edit: August 23, 2017, 11:30:59 PM by Plexi »
Plexi
« Reply #9 on: September 09, 2017, 08:57:32 PM »
What would happen, theoretically speaking, if I switch C4 to 10uF?
Less overall distortion?
« Reply #10 on: September 09, 2017, 09:24:35 PM »
Man, I read the thread topic, saw the author's name, and was worried we were dealing with a medical crisis!  :icon_razz:
No affiliations. If I glowingly mention specific merchants or products, it is because I like them without having to be paid to like them.
Plexi
« Reply #11 on: September 09, 2017, 09:27:11 PM »
...don't forget the purple-face of the avatar guy.....  :icon_redface:
 ;D
