Old Ibanez Super Tube Pots replacement
Started by nonoxxx, September 05, 2017, 05:35:51 AM
nonoxxx
Hello
Some pots of a friend's Ibanez Super tube pedal are dead, and I was looking for replacements ones that will be ideally direct replacements.
these pots are non standards stomp boxes pots ... :
After measuring and  looking at the alpha website these ones should fit perfectly  withe the reference 3RP/1201N shaft type B ...
  http://www.alphapotentiometers.net/html/12mm_pot_6.html
But what the meaning of ' shaft shown in full C.C.W' position ?   and does someone know where to find these pots , I take a look at mouser's website and don't find this reference ..
antonis
Quote from: nonoxxx on September 05, 2017, 05:35:51 AM
Exactly what it says..  :icon_wink:
Pot turned all the way counter-clockwise (resistance between leg 1 & 2 almost zero..) so the shaft flat cut surface vertical axis is set at 300 right from the lenghtway (longitudinal) axis..
(it's shown to plan the respective knob fit/cut in case of existence some kind of pointer..)
nonoxxx
Thanks,
I had not thought about counter clock wise where reading ccw ... hahhahhah
antonis
My bad...  :icon_redface:
I should write DLSIDAdUM...  :icon_wink:
(dans le sens inverse des aiguilles d'une montre..)
nonoxxx
I hate anacronyms lol (as a software developper , I think I heard too much of ASCII... PHP...DNS.. WAMP ..)
nonoxxx
Any clue for a website to buy these alphas  12 mm?
