LTspice noob question
Started by suryabeep, September 07, 2017, 12:18:53 AM
suryabeep
Hi everyone,
dunno if this is the right place to post this, but I have a noob question about LTspice. I just downloaded it today and started with a common emitter amplifier to warm up. I'm using LPB values, but it doesn't work. What did I do wrong?
Still in the process of learning, so bear with me if I ask dumb questions :P
antonis
LTspice (and its symbols) isn't familiar to me but is actually R4 0.001 Ohm..???
GibsonGM
Quote from: antonis on September 07, 2017, 07:36:59 AM
With LT you must say "1MEG" for 1 megohm...I think, as Antonis says, "1m" makes it divided by 1,000!
After you run the simulation, if you do not see your output signal, double-click the output node ("OUT").
