Klon centaur clone
Started by ward, September 07, 2017, 07:04:49 AM
ward
Hi,
My centaur klon is giving me headaches,
the pedal is working, the pots are working as should.  Only the gainpot has some scratchiness.
But the big problem is a squeal or oscillation at around 4khz.
This is the layout I used,
http://effectslayouts.blogspot.be/2016/01/klon-centaur.html?m=1
This is my reference schematic,
https://aionelectronics.com/wp-content/uploads/2013/11/klon-centaur-schematic.png
I didn't use any switching scheme.  The pedal is to be controlled with a switcher.  So the output comes directly  from the wiper of the volume pot.
antonis
Replace Gain pot, as a start...
(the way the pot is connected may result in oscillation in case of pot set in "scratchy" area..)
I know I read something a long time ago about adding a cap somewhere to take care of whine due to instability.....  I'm still trying to find it.
So you're looking for the whine list, Eric?  :icon_biggrin:
I'll get my coat...  ::)
ward
Its solved....
I replaced the ICL7660SCPA and away it went ...
A bad chip I suppose
