Author Topic: Combining different types of 9mm pots  (Read 361 times)
« on: September 13, 2017, 07:11:16 PM »
I have wads of those little green PCB-mount 9mm pots with the black plastic shafts, and only recently purchased some of the more costly ones with metal shafts that can be secured to a chassis with a retaining nut.  IN past, I have deftly mounted the blastic shaft type to a chassis with some epoxy, but it is tricky.
I'm wondering if I can combine the plastic and metal shaft types and expect a reasonable degree of mechanical stability.  More specifically, if I was to solder one of the chassis-mount metal-shaft types to a piece of pad-per-hole board, along with a black-plastic type on either side of it, soldered to the same pad-per-hole board, could I expect the pot secured to the chassis, and the chassis holes for the black plastic one to keep everything steady enough that it wouldn't suddenly give?
I'm trying to make it easier to build stuff into 1590A boxes, and this seems like a reasonable compromise between lower cost and structural reliability.  I'm wondering if others have tried or seen a similar arrangement.
antonis
Re: Combining different types of 9mm pots
« Reply #1 on: September 14, 2017, 04:48:13 AM »
Some women like squeeze but no plastic-threaded pot does..!!  :icon_wink:
My experience is limited to the use of some kind of "Nylock" securing nuts (the ones with a nylon collar inside the nut) with very good stability results but with the drawback of "off-setting" knob from enlosure surface..
(at distance depending on internal knob cavity & nut external diameter and height..)
edit: I'm talking about full-plastic pots, of course..
Maybe I didn't get Mark's query if it's about shaft only durability..  :icon_redface:
« Last Edit: September 14, 2017, 05:09:11 AM by antonis »
Tired of updating my account to enable 3rd party hosting..
« Reply #2 on: September 14, 2017, 04:56:18 AM »
i would think it would be ok, as long as you dont give it a really good kicking.
if you are, then stick a little protector bar on there...
i use those 'no shaft' 9mms on breadboards...ideal. 8)
i like to put a little dab of white paint in the notch groove, so i can see the dial.  :icon_idea:
« Last Edit: September 14, 2017, 04:58:21 AM by deadastronaut »
http://www.youtube.com/user/100roberthenry
http://deadastronaut.wix.com/index
^ SPACE PATROL FUZZ/ NANO-8 MIDI DRUMS /CHASM REVERB / TREMSHIFTER / FAZE FILTER/ABDUCTOR II DELAY pcb's + WAH LIGHT PLATES. and sausa
« Reply #3 on: September 14, 2017, 08:20:19 AM »
That's a good tip.  If one still  has a bottle of white-out/liquid paper sitting around (in unsolidified form), a dab of that and a quick wipe to remove excess should work nicely.
marcelomd
« Reply #4 on: September 14, 2017, 04:32:40 PM »
Nail polish works as well.
Ice-9
« Reply #5 on: September 14, 2017, 05:39:24 PM »
If these are the types of pots you mean Mark they fit perfectly and sit at the correct heights with the other pots when soldered to a board, in this picture I have them on my PCB's but vero or any board mounting should work fine and the metal shaft pot(s) hold everything else in the correct place.
+1 for having to paint in the white position line.
« Last Edit: September 14, 2017, 05:42:04 PM by Ice-9 »
It's fairly straight forward, if you want to start it , press start. You can work out the rest of the controls for yourself !
Do me a lemon, that a poor IQ for a glass of water.
