Author Topic: Voodoo Lab Sparkle Drive - tone suggestions  (Read 479 times)
« on: September 27, 2017, 12:02:44 AM »
I just finished a nice build of a Voodoo Lab Sparkle Drive pedal. I am actually using it to add some grind to my acoustic guitars. The ability to mix the clean channel with the distorted channel makes this an ideal pedal for my application.
The problem I am having is that the tone pot only controls the tone for the drive channel. If I have modified the tone at all, then the tone varies progressively when I adjust the channel blend.
Ideally, I am looking for a way to add a similar tone control to the clean channel.
For reference, here is a link to the component layout I used, from tagboardeffects.
Re: Voodoo Lab Sparkle Drive - tone suggestions
« Reply #1 on: September 27, 2017, 09:59:23 AM »
Wrong forum, you will get better response if you post this in the correct forum room. This is the digital and DSP room.
It's fairly straight forward, if you want to start it , press start. You can work out the rest of the controls for yourself !
Do me a lemon, that a poor IQ for a glass of water.
