Ce2 dual speed depth stompswitch
Started by skumberg, October 06, 2017, 05:25:36 PM
skumberg
I have a tonepad Ce2 in a 1590BB and there is room for an extra stompswitch. I'm trying to figure out what would be useful. Analogman sell a bi Chorus with two sets of speed and depth knobs. How would you build this with the Ce2 lfo? Can I just wire the potentiometers in parallel and switch the wipers? If so, because the original uses 100kb pots, would then 200kb potentiometers work better?
Fp-www.Tonepad.com
If you want two lfos why not build a second LFO circuit, then you can take a dpdt switch and switch between the wipers of the two depth pots. That would be the way to do it.
not a bad idea for a little add on pcb.
look at IC2a and it's surrounding components in the pdf.
http://tonepad.com/project.asp?id=53
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
