Low pass filter gain compensation
Started by marcelomd, October 15, 2017, 05:07:43 PM
marcelomd
Hi guys,
I'm playing with a variable frequency low pass filter (100Hz-5kHz). Just a simple potentiometer wired as variable resistor and a capacitor into an opamp.
The problem is that the variable resistor messes with the amplitude of the signal in the passband. Is there a (simple and/or usual) way to counter that and keep the pass band at unity gain?
With the values I'm using, the passband at the lowest setting is -9dB and -30dB at the highest.
Thanks a lot!
To avoid attenuation you need the pot resistance (the largest resistance of the filter) to be 10 times *smaller* than the load. Yours looks like it is 30 times larger.
However, I doubt you will be able to do it with such a large frequency control range.  So what you will need to do is put a buffer between the low-pass filter and the circuit.
marcelomd
I'm trying to split my signal in two, high and low frequencies. I want to adjust both frequencies independently, a la Dug Pinnick's signature amp (that's where I got the frequencies from, but it's just a guideline).
My low side signal chain so far is [Voltage follower]->[variable low pass filter]->[inverting buffer]->[inverting mixer, with high side]. Pretty much like this. My filter is already sandwiched between buffers.
I calculated a 50k pot (and a 1k limiter) plus a 33n cap. I guess I can lower the values and keep the proportion.
Quote>[variable low pass filter]->[inverting buffer]
The inverting buffer is the problem.  It has medium input impedance.
This is what is loading the low-pass filter.   Hard to get around the problem.
In the link you gave the buffer is non-inverting.  It doesn't load the low-pass filter
and avoids the problem.
Try to change it to:
[variable low pass filter]->[non-inverting buffer]->[non-inverting mixer, with high side].
QuoteI guess I can lower the values and keep the proportion.
You will struggle to get it to work unless you have very large resistors on the inverting buffer (which cause noise).
marcelomd
Aaaaah now it works as expected. I thought a JFET opamp had enough impedance in this case.
I wanted to save a stage and still be phase correct at the output. I guess I'll put a simple common emitter after everything.
Thanks a lot!
