Improving the Sound of MkIII Tone Bender
Started by ItsGiusto, October 21, 2017, 01:50:37 PM
ItsGiusto
A few years ago I build a MkIII tonebender according to this schematic:
I've never fully liked the sound of it - it's a little compressed and not bassy enough. It doesn't sound as wild as the MkII I built at the same time.
I was wondering if I should modify it. Looking, for example, at what I think is a Fulltone Soul Bender schematic:
I can see that there are numerous differences. Mostly there are resistor, cap, and pot value changes. But there's also architecture differences - the Soul bender has some type of lowpass filter after the volume knob, and very interestingly, C7 is connected via a trimpot to the output of the "dirt" pot.
I'm wondering if I should implement some of these changes, or all of them, but I'm also a little afraid of making the changes and realizing I liked it better before. What would be the effect of these changes, especially the added trimpot connection?
I put the plans together so I don't get whip-lash looking back and forth.
I don't see much difference. R1 is unimportant. 100/220pFd if probably very small. The more-treble side of the tone pot looks different enough to try (tho I wonder if it is a typo). The 500K trim is a real difference worth trying.
ItsGiusto
In thinking this over a little more, could the connection with the trimpot be acting as a positive feedback? Like the "positive feedback applications" section here:
https://en.m.wikipedia.org/wiki/Operational_amplifier
It's a transistor, not an opamp, but maybe it had a similar effect, of increasing output gain?
mac
Boutique Bender:
That's a C to B variable resistor, NF used in Silicon versions to feed the base.
There is no 10k to Gnd like in the other schematic, R11.
Focus on C6 and C7.
mac
It is negative feedback, reduces gain, BUT it also adds bias to that transistor. Without it, that transistor has no bias, cuts-off small signals.
Kennt82
The Earthquaker Devices Tone Reaper is based on the TB MKIII, but VERY bassy. It's a Muff tone stack with unusual values.
