CD4049 momentary to latching - power up in known state?
Started by composition4, October 25, 2017, 11:49:32 AM
composition4
Hi all,
Possibly a simple one.. is there any way to make an inverter-based latch such as this one from RG's site power up in a known state?
I'm thinking I may be able to achieve it by holding a pin high with a cap on power-up or somethuing similar but can't get my head around it at the moment.
Jonathan
marcelomd
A few weeks ago I was looking for something similar and found this:
https://electronics.stackexchange.com/questions/186841/momentary-button-as-switch
The first answer explains how to do it. They used it for controlling a PC power supply, but the theory is the same.
In the end I used the circuit you posted as it always powered up the way I wanted. I had to play with the resistor values a bit to reduce bouncing.
marcelomd
composition4
